- Platform information:
- Hardware: Raspberry Pi 3 Model B Plus Rev 1.3
- OS: Openhabian
- openHAB version: 2.4.0
- Issue of the topic:
I am running the standard openHab backup script once every 2 weeks, but recently (last 2 months), the size of the backup zip file has grown a lot…
In the beginning of January the size was about 15Mb, but every file since then has become larger and larger. The latest from 1. March was 53GB (!). I have not made any changes to the system in the timeframe. I am running influxdb to persist a little weather data for graphs on my habPanel and that’s it apart from standard items/rules etc.
Does anyone have an idea as to what can be going on? (I am only using 3GB on the SD card in the raspberry, so a 53GB backup file seems a little over the top:-) )
I am inserting the data from my influx.persist and my backup.things (which saves the backup on a mounted NAS) as I have no idea what other files could be interesting in this case.
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
Items {
TemperatureOut, TemperatureSensorCurrentTemperature, GPresent : strategy = everyChange, everyHour
Windspeed, CPU_Load1 : strategy = everyHour
Thing exec:command:backup [
// Command to execute
command="sudo /usr/share/openhab2/runtime/bin/backup /etc/openhab2/sharednas/%1$tY-%1$tm-%1$td-%1$tH-%1$tM",
// interval time in seconds
interval=0,
// should it run when input channel is changed
autorun=false]
Thank you very much for your replies.
Cheers,
Peter
Edit: I see now that the backup files are contained inside the data being backed up - the backup then doubles every time…how stupid of me:-)
