Hi
I m using the Openhab Project from ThomDietrich. The Project was running on a Raspberry, Due to the fact that the Raspberry is to slow i moved everything to my Synology. I installed Openhab and moved the files aswell.
Now i have a problem with the summary funtion that ThomDietrich implememted in the Projetc. when i add this Line
Group:NUMBER:SUM Heating_WindowModes "Fensterabsenkung [%s]" <window> (Heating_Group)
i get this Error
16:50:26.981 [WARN ] [del.core.internal.ModelRepositoryImpl] - Configuration model 'homematic-heizung.items' has errors, therefore ignoring it: [13,7]: no viable alternative at input 'NUMBER'
[13,13]: missing EOF at ':'
When i deactivate the Line the project is running fine. Where do i have to search to fix it?
