I installed Openhab in a windows10 machine for testing.
Everything works great BUT there is a security concern …every time i connect to http://localhost:8080 or from outside using the Openhab app from my phone http://xxxx.com:8080 i get in without any credentials and from brower too.
Of course you understand my frustration since anyone can see my openhab and enter without login password.
I cannot find anything for windows platform to make openhab ask for username/password , can you please give me some info .
Thank you !!!
Core2 Duo with 4gb ram
Windows 10 Pro
jdk1.8.0_231
Openhab 2.4.0
OpenHAB itself has no credential system. If you are on your local network, security concerns should be minimal.
You can follow the documentation to secure it better though.
Well after some coffee i found the note : openHAB does not (yet) support restricting access through HTTP(S) for certain users - there is no authentication in place, nor is there a limitation of functionality or information that different users can access.
So i used the Openhab cloud connector and its ok for now.
