- Platform information:
- Hardware: Raspberry Pi 3 Model B Rev 1.2
- OS: openHABian (current release) / Raspbian GNU/Linux 8 (jessie)
- Java Runtime Environment: openjdk version “1.8.0_152”
- openHAB version: 2.5.0~S1479-1 (Build #1479)
- Issue of the topic:
Today I updated my OH2 installation by using the openhabian-config tool. The tool first updated itself and then I did a OH2 update. After restarting OH2, the dashboard is not reachable (instead a message is shown that the UIs are being configured). After a while (approximately 10 minutes) the following message inopenhab.log
comes up:
2018-12-26 12:16:58.015 [WARN ] [shd.server.session.ServerSessionImpl] - exceptionCaught(ServerSessionImpl[openhab@/127.0.0.1:60724])[state=Opened] InterruptedByTimeoutException: null
[SOLVED] openHAB not starting after update (ServerSessionImpl - InterruptedByTimeoutException: null)
After updating you may want to try cleaning the cache and rebooting. You can use the following commands for this.
sudo systemctl stop openhab2
sudo openhab-cli clean-cache
sudo reboot
For my server a single reboot worked but others have reported that rebooting a few times was needed.
Hope this helps.
Thank you very much. Cleaning the cache made it working again!
Glad to hear you have it working.
In addition to editing the title, please click the square box (lower right corner) on the post that provided the solution.
