**16:48:51** [INFO] Adding repository https://openhab.jfrog.io/openhab/eclipse-smarthome-stable
**16:48:54** [ERROR] Internal error: java.lang.RuntimeException: Failed to load p2 repository with ID 'p2-smarthome' from location https://openhab.jfrog.io/openhab/eclipse-smarthome-stable: Artifact not found: https://openhab.jfrog.io/openhab/eclipse-smarthome-stable/content.xml.xz. -> [Help 1]
**16:48:54** org.apache.maven.InternalErrorException: Internal error: java.lang.RuntimeException: Failed to load p2 repository with ID 'p2-smarthome' from location https://openhab.jfrog.io/openhab/eclipse-smarthome-stable
The check - even with a plain fork - currently fails. Any hints?
