Hi All this is my first thread, sorry for my bad english and because I’m a beginner.
I installed on my qnap in a container the version of openhab 2.4. I have a very old bticino system, and my gateway is a F453AV, I have even managed with the old 1.X bindings to configure all the lights.
Now i have installed the OpenWebNet Binding (beta9-2) of the great Massi (Very Thanks). I tried to configure my first window automation and then I would like to try to open the gate connected to the video door phone.
This last one works with this frame in bus scs :
Remember to enter the correct password
Run it all through PaperUI, after we see the sitemaps
If you have problems publish the log, so we can see what kind of error
At the moment it is not possible with 2.0 bindings
You can do it with bindings 1.0
Thank you for the quick reply.
I put the right password only I did not report it here. The password is the default one: 12345
The Gateway bus is ON-LINE, instead the automation does not.
Now I try from the physical command to see what happens.
I tried with version 1.0 of the bindings but I did not succeed now put the settings:
Item:
Unknow …
I pressed the physical command but tells me unknown.
I have the doubt that I was wrong in the command where=“91”
There are a way to find out the exact address of this automation?
I solved now the problem with mi open door …
I put in my item : {bticino=“if=webserver;who=6;what=10;where=4000”} and not {bticino=“if=default;who=6;what=10;where=4000”} and this solved the problem.
Best regards to all.
Ivan
Oh Thanks!
On the PC browser everything works perfectly, while on the smartphone application it does not show me the icons.I believe the application of the mobile only has the icons of the basic set of openhab?
Regards
Ivan
The first is a bit off topic, is there a way to make google home upload the new openhab devices without disconnecting and reconnecting the openhab skill?
I noticed that the automation of the window I mentioned with the [“Blinds”] tag on google home is not recognized, i have configured Configuration > System > Item Linking > Simple mode > SAVE but nothing has changed.
Ivan
Thanks Michele for the super fast response.
I’m waiting to know if anyone else knows how to do it.
This method that you showed me was very useful to configure a bell that has the frame * 1 * 0 * 81 ## that is controlled by the cords that are in the bathrooms. I configured how you taught me and I play it for one second each time the command is played.
Very useful then thank you!!
Ivan
Sorry for my bad translate …
