i’m using correctly openhab 2.4; to use zwave dognle i need every restart to give /dev/tty permission with:
“sudo chown openhab:openhab /dev/***” and then works.
Now i have 2 questions:
is possibile to run it with sudoers permission?
i’m trying to use socat (rs232-tcp for EpsonPJ) but i can’t give openhab user to it so i can’t use that port
Any suggestions?
thanks in advance!
Thanks for help.
I added Openhab user to dialout group.
Then, with this:
pty,link=/dev/vircom0,raw,user=openhab,group=dialout,mode=777 tcp:x.x.x.x:port
@khael87 glad I could help and happy to see it’s working working.
If you would please mark the topic solved by clicking the square box (lower right corner) on the post that provided the solution. This helps other with a similar issue find a quick solution.
