I am suddenly having problems getting the OpenHAB service to run. OH will start from the command line tool but I cannot get the service to start. Happened after installing jython?..
[09:27:05] openhabian@openHABianPi:~$ sudo systemctl start openhab2
[09:27:18] openhabian@openHABianPi:~$ sudo openhab-cli status
A systemd service configuration exists...
Use 'sudo /bin/systemctl status openhab2.service' to find the status of an openHAB service
openHAB is not running.
[09:27:27] openhabian@openHABianPi:~$ sudo systemctl status openhab2
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2018-09-22 09:27:41 CDT; 158ms ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 10993 ExecStop=/usr/share/openhab2/runtime/bin/karaf stop (code=exited, status=1/FAILURE)
Main PID: 11113 (karaf)
CGroup: /system.slice/openhab2.service
├─11113 /bin/sh /usr/share/openhab2/runtime/bin/karaf daemon
├─11128 /bin/sh /usr/share/openhab2/runtime/bin/karaf daemon
├─11129 /bin/sh /usr/share/openhab2/runtime/bin/karaf daemon
├─11130 /bin/sh /usr/share/openhab2/runtime/bin/karaf daemon
├─11141 /bin/sh /usr/share/openhab2/runtime/bin/karaf daemon
├─11146 /bin/sh /usr/share/openhab2/runtime/bin/karaf daemon
├─11150 /bin/sh /usr/share/openhab2/runtime/bin/karaf daemon
├─11153 /bin/sh /usr/share/openhab2/runtime/bin/karaf daemon
├─11157 /bin/sh /usr/share/openhab2/runtime/bin/karaf daemon
└─11160 /bin/sh /usr/share/openhab2/runtime/bin/karaf daemon
Sep 22 09:27:41 openHABianPi systemd[1]: Started openHAB 2 - empowering the smart home.
