[SOLVED] OpenHab2 interface not updating after KNX event
Dear OpenHab comunity,
Using Openhab2 I can fully control every KNX device (with the UI, with the Android app, with myopenhab cloud service, and even even using Amazon Echo). If I change on a light using the mobile app, the UI is update and viceversa.
But if I switch on a light using a wall switch, the light comes on but the Openhab interface is not updated!
Looking at the log file nothing happens when I use a wall switch.
This is my configuration:
  • Openhab version: 2.2.0
  • KNX binding 1.9
  • Gira router
  • KNX conf file (knx.cfg)
    ip=224.0.23.12
    ignorelocalevents=true
    type=ROUTER
  • Example of item in demo.items file
    Switch Light_Living_Table “Table” (Room_Living, Lights) {autoupdate=“true”, knx=“0/2/9”}
Thanks,
Alex
