I am experiencing almost the same problem:
Platform: Mini-PC Celeron amd-64 architecture, Ubuntu 18 and OH 2.3.0 Stable
After a cold restart the System binding would not deliver some CPU-information (load and temperature).
On advise from @H102 I reinstalled the binding but no progress. Then I cleaned the cache and tmp files using the commands openhab-cli stop, openhab-cli clean-cache, openhab-cli start.
Since I am running the PC headless, I did this over SSH.
So, OH started, everything OK but now I was stuck in Karaf. Logging out or closing the session also terminates OH .
I solved this by connecting a screen and keyboard locally to the PC but I am not able to start OH the usual way by systemctl. openhab-cli start does start OH and it is running with everything up as before.
Now OH is running fine since yesterday. I could disconnect the screen and kbd but when I log in via SSH and check the status, I get this info:
[10:33:23] openhab@ib9-oh2-2:~$ systemctl status openhab2.service
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Tue 2018-11-27 10:33:34 CET; 4s ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 23792 ExecStart=/usr/share/openhab2/runtime/bin/karaf $OPENHAB_STARTMODE (code=exited, status=1/FAILURE)
Main PID: 23792 (code=exited, status=1/FAILURE)
I am fairly experienced with OH, starting with 1.8 on a RPi but when it comes to Karaf, I am a noob.
What I have not done so far is reinstalling OH.
sudo su //switch permanently to root (optional)
systemctl stop OH2 //stop the OH2 service
mv /var/log/openhab2/openhab.log /var/log/openhab2/openhab.log.old //keep a copy of the log
openhab-cli clean-cache //clean cache
systemctl start OH2 //start OH2
systemctl status OH2 //check status
tail -f /var/log/openhab2/openhab.log //monitor log file
Thanks for your support!
That did the trick but I had to do it from the console on the PC itself. The OH2 instance was running there and I could not stop it from the SSH session.
Look for the line that has openhab in the first column, unless OH is running as a different user in which case look for the line that has java -Dopenhab.home= in it.
The second column will be the PID for the running OH. 18183 in the example above. You can nicely stop the program with the command sudo kill -HUP 18183 or immediately end the program without giving it a chance to shutdown with sudo kill -9 18183. Of course, replace the PID with your PID.
Similar problem here - OpenHAB did not start after an apt update - those steps solved it form me. Currently waiting for the Paper UI to become available again.
You only need to follow those instructions if you’re installing openHAB 2 manually using a zip file. You should remove that file if you are using apt to manage the install, as this is done for you.
