[SOLVED] OpenHAB2 spontaneously crashed and now refuses to start?
New user of OpenHAB here, running version 2.0.0-STABLE on Debian Jessie on a headless Frankenputer server. Sometime today OpenHAB2 crashed. I tried to restart it, but it refused to start. Here are the error logs:
After first crash:
kit@viki:/var/log/openhab2$ sudo systemctl status openhab2.service
[sudo] password for kit:
● openhab2.service - openHAB 2 - empowering the smart home
   Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
   Active: active (running) since Wed 2017-04-05 23:02:57 BST; 1min 7s ago
     Docs: http://docs.openhab.org
           https://community.openhab.org
  Process: 28928 ExecStop=/usr/share/openhab2/runtime/bin/stop (code=exited, status=1/FAILURE)
 Main PID: 29104 (karaf)
   CGroup: /system.slice/openhab2.service
           ├─29104 /bin/bash /usr/share/openhab2/runtime/bin/karaf server
           └─29251 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share...
From openhab.log:
2017-04-05 15:11:34.217 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 13: Node is DEAD. Dropping message.
2017-04-05 15:11:38.315 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 13: Node is DEAD. Dropping message.
2017-04-05 15:11:42.429 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 13: Node is DEAD. Dropping message.
2017-04-05 15:11:46.573 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 13: Node is DEAD. Dropping message.
2017-04-05 15:11:50.717 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 13: Node is DEAD. Dropping message.
2017-04-05 15:58:52.393 [SEVERE] [org.apache.karaf.main.Main] - Could not launch framework
java.lang.SecurityException: cannot verify signature block file META-INF/ECLIPSE_
        at sun.security.util.SignatureFileVerifier.processImpl(SignatureFileVerifier.java:295)
        at sun.security.util.SignatureFileVerifier.process(SignatureFileVerifier.java:268)
        at java.util.jar.JarVerifier.processEntry(JarVerifier.java:316)
        at java.util.jar.JarVerifier.update(JarVerifier.java:228)
        at java.util.jar.JarFile.initializeVerifier(JarFile.java:383)
        at java.util.jar.JarFile.getInputStream(JarFile.java:450)
        at sun.net.www.protocol.jar.JarURLConnection.getInputStream(JarURLConnection.java:162)
        at java.net.URLClassLoader.getResourceAsStream(URLClassLoader.java:238)
        at org.apache.karaf.main.Main.loadFrameworkFactory(Main.java:425)
        at org.apache.karaf.main.Main.launch(Main.java:252)
        at org.apache.karaf.main.Main.main(Main.java:177)
After second crash:
kit@viki:/var/log/openhab2$ sudo /etc/init.d/openhab2 restart
[ ok ] Restarting openhab2 (via systemctl): openhab2.service .
   Active: active (running) since Wed 2017-04-05 23:07:16 BST; 7s ago
  Process: 31544 ExecStop=/usr/share/openhab2/runtime/bin/stop (code=exited, status=1/FAILURE)
 Main PID: 31718 (karaf)
           ├─31718 /bin/bash /usr/share/openhab2/runtime/bin/karaf server
           └─31865 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share...
openhab.log hasn’t been edited since 15:58 on 5th April, the time of the first crash. I’m a bit confused by the systemctl status saying it’s active, but the process has exited due to a failure?
How do I start to troubleshoot this issue? The best clue I can see is “java.lang.SecurityException: cannot verify signature block file META-INF/ECLIPSE_” but no-one was logged into the server at that time, so no-one was editing/changing anything? I’m also suspecting hardware failure, so am running a few hardware tests as well, but if someone has some pointers for me, I’d really appreciate it. Thanks!
Checked out the hardware, all working perfect in good working order.
Any ideas? I’d really like to get it back up and running again!
Many thanks!
Can you do an update or re-install of OH2? Depending on how your setup, I think that should be safe enough without losing any items info or bindings.
Per perhaps back up your /etc/openhab2 folder first /usr/share/openhab2 folders just in case.
Thanks for response! Uninstalled and reinstalled OH2 - still doesn’t work, but it shows different error, again related to Java, so I decided to uninstall and reinstall Zulu… and now it works. Curiouser and curiouser…
