I believe it won’t work with default miio_client implementations because it uses another messaging patterns. Implemented binary by @rothm uses straight plain-text communication while original miio_client requires tokens and encoding/decoding messages. I may be wrong, but this is how I remembered it.
@cadavre Yes, it don’t think it will work out of the box with my “miio_client without encryption” / “miio_client passthrough” which forward each request to the “gw” / gateway client.
The firmware / ota should be processed by the original / vendor miio_client.
Guys, i have one aqara hub that after flashing immediate firmware flash simply bricked itself and therefore i cannot use it. I did manage to root to it and have access to it, have already tried to manually fix the thing, but without success I was wondering, if any1 of you successfully using it can send me the .bin file of a working hub?
during inspection of the device via root access, i saw that there might be some sensitive data (like wifi credentials and stuff) so you can simply write dummy values there, but pls tell me which files did you change
please, if someone can help me with this one, i would be very grateful. if not, at least point me in some direction on what i can possibly do with that device?
I am desperate. Have connected the gateway with putty and can see everything. Unfortunately, I can not enter anything. I am very inexperienced with Putty. I read that you have to copy the cmd commands. I do not know how it works. I would be very grateful for your help.
I am trying to follow the fix at the moment. However I don’t see anything at all when I try and connect with putty. Does anyone have any ideas or suggestions for me to try? I would love to get the hub working…
Ok so if it’s not about opening the ports, what should I do now? I’m trying to connect the gateway to domoticz running on a Raspberry Pi. I managed to reset the root password and when I run the netstat command I get the same result as you.
Hi, i wonder if someone can help me. I have followed the guide and have connected GND from TTL to GND of the Gateway. Then i connected TX from Gateway to RX on TTL and connected it to the USB. Then i powered the gateway. When i try to connect with Putty, i use 115200 for baudrate and COM1. Putty then opens a new window witch stays blank. I dont what im doing wrong. Any help would be nice.
Hey guys! Thanks for the info above. I’ve already connected to my gateway, but when I enter psm-set network.open_pf 3 it answer me psm_set_variable() failed with: -1.
psm-get network.open_pf answer 2. Ports are closed, try to restart the gateway - nothing, try to check and play with rx\tx wires - nothing.
I can’t find any information about that. Could you help me?
When I apply AC to the gatewy, the serial link is not connected (Rx, Tx, GND not connected).
Just after applying AC to the gateway, I connect the serial link (Tx, Rx, GND) between the PC and the gateway and send “enter” with Putty.
I am using the EU version of the gateway of course.
