Platform information:
- Hardware: _RPI2
- openHAB version: openHabian 1.4
Trying to install from mSATA drive connected via USB
SD card Etcher formated with Raspbian Lite, I modified the cmdline.txt with root=PARTUUID=mypartuuid, it’s booting, OpenHabbian starts to install, until I get this error message: -
[openHabian] Cloning myself… FAILED
And the installation stops.
Before, i was able to install from SD, no problems.
What am I doing wrong? Do I need to modify a file in the sATA drive? Thanks, Chris
2017-11-29_02:37:35_UTC [openHABian] Starting the openHABian initial setup.
2017-11-29_02:37:35_UTC [openHABian] Storing configuration… OK
2017-11-29_02:37:35_UTC [openHABian] Changing default username and password… OK
2017-11-29_02:37:37_UTC [openHABian] Setting up Ethernet connection… OK
2017-11-29_02:37:37_UTC [openHABian] Ensuring network connectivity… OK
2017-11-29_02:37:38_UTC [openHABian] Waiting for dpkg/apt to get ready… OK
2018-01-12_10:46:50_UTC [openHABian] Updating repositories and upgrading installed packages… OK
2018-01-12_10:52:33_UTC [openHABian] Installing git package… OK
2018-01-12_10:53:26_UTC [openHABian] Cloning myself… OK
2018-01-12_10:53:32_UTC [openHABian] Executing ‘openhabian-setup.sh unattended’…
2018-01-12_10:53:32_UTC [openHABian] Checking for root privileges… OK
2018-01-12_10:53:33_UTC [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
2018-01-12_10:53:33_UTC [openHABian] Setting timezone based on IP geolocation… OK (Europe/Zurich)
2018-01-12_11:59:21_CET [openHABian] Setting locale based on openhabian.conf… OK
2018-01-12_12:01:15_CET [openHABian] Setting hostname of the base system… OK
2018-01-12_12:01:16_CET [openHABian] Setting the GPU memory split down to 16MB for headless system… OK
2018-01-12_12:01:16_CET [openHABian] Enabling Audio output… OK
2018-01-12_12:01:18_CET [openHABian] Installing basic can’t-be-wrong packages (screen, vim, …)… OK
2018-01-12_12:04:56_CET [openHABian] Installing additional needed packages… OK
2018-01-12_12:05:43_CET [openHABian] Adding slightly tuned bash config files to system… OK
2018-01-12_12:05:43_CET [openHABian] Adding slightly tuned vim config file to system… OK
2018-01-12_12:05:43_CET [openHABian] Downloading and setting up FireMotD… OK
2018-01-12_12:07:38_CET [openHABian] Installing Zulu Embedded OpenJDK… OK
2018-01-12_12:12:28_CET [openHABian] Installing or upgrading to latest openHAB release (stable)… FAILED (apt)
2018-01-12_12:13:20_CET [openHABian] Initial setup exiting with an error!
2018-01-12_12:55:39_CET [openHABian] Starting the openHABian initial setup.
2018-01-12_12:55:39_CET [openHABian] Storing configuration… OK
2018-01-12_12:55:40_CET [openHABian] Changing default username and password… SKIPPED
2018-01-12_12:55:40_CET [openHABian] Setting up Ethernet connection… OK
2018-01-12_12:55:40_CET [openHABian] Ensuring network connectivity… OK
2018-01-12_12:55:40_CET [openHABian] Waiting for dpkg/apt to get ready… OK
2018-01-12_12:57:28_CET [openHABian] Updating repositories and upgrading installed packages… FAILED
2018-01-12_12:58:57_CET [openHABian] Initial setup exiting with an error!
2018-01-12_13:05:52_CET [openHABian] Starting the openHABian initial setup.
2018-01-12_13:05:52_CET [openHABian] Storing configuration… OK
2018-01-12_13:05:53_CET [openHABian] Changing default username and password… SKIPPED
2018-01-12_13:05:53_CET [openHABian] Setting up Ethernet connection… OK
2018-01-12_13:05:53_CET [openHABian] Ensuring network connectivity… OK
2018-01-12_13:05:53_CET [openHABian] Waiting for dpkg/apt to get ready… OK
2018-01-12_13:06:53_CET [openHABian] Updating repositories and upgrading installed packages… OK
2018-01-12_13:07:48_CET [openHABian] Installing git package… OK
2018-01-12_13:07:55_CET [openHABian] Cloning myself… FAILED
2018-01-12_13:07:55_CET [openHABian] Initial setup exiting with an error!
