openhabian-config v1.5-522 gives me the following error in option ‘31 | Change Hostname’: ‘The hostname you’ve entered is not a valid hostname. Please try again.’
and it will not accept any host name at all.
Worked fine last time I tried a rebuild which was with v1.5-520.
What OS?
Same issue for me with 1.5-522, after a new install with the Raspbian Buster openHABian image on a Raspberry Pi 4.
raspbian-201908050414 (which is Buster) but I have the same problem when I tried the previous release of raspbian from 2018.
Tried on RaspberryPi Model 3B. Also tried on a Model 2B.
The OpenHABian devs insist on removing raspi-config
rather than work around any conflicts… Those developers need to insure they replicate ALL the functionality they remove.
I have located the source of the problem.
In openhabian-config v1.5-520, there is a line in file /opt/openhabian/functions/system.bash which reads:
new_hostname=$(whiptail --title "Change Hostname" --inputbox "Please enter the new system hostname (no special characters, no spaces):" 10 60 3>&1 1>&2 2>&3)
if [ $? -ne 0 ]; then return 1; fi
if ( echo "$new_hostname" | grep -q ' ' ) || [ -z "$new_hostname" ]; then
whiptail --title "Change Hostname" --msgbox "The hostname you've entered is not a valid hostname. Please try again." 10 60
but in openhabian-config v1.5-522 it reads:
if ! whiptail --title "Change Hostname" --inputbox "Please enter the new system hostname (no special characters, no spaces):" 10 60 3>&1 1>&2 2>&3; then return 1; fi
So the new version of this script refers to the variable $new_hostname
which has not been set to anything and hence is invalid.
I feel quite foolish. I have never used GIT before to contribute but I can’t seem to successfully create a Pull Request.
e.g. I have created my own fork from openhab/openhabian and I have modified system.bash but I do not know how to create the pull request so my change can be considered for inclusion in the master. Any idea what I should be doing?
@mljbr4 I had the same issue don’t feel silly. The interface is not the most obvious. I am still not sure I could do it again fast.
Ops, this indicates that we (the community) did not do a good job helping users to get started contributing Sorry for that.
If you need help let me know.
It’s easiest if you use the Github GUI and edit the file online. With CLI git it is a bit of fiddling.
Create a Github repo (using Web GUI) and on your box, git add remote URL yourrepo
, then git push yourrepo
. It’ll return you a link, follow that to create the PR.
