While my OpenHABian installation has been running happily since March 2017 and has just upgraded to OH2.1 without problems, I have an issue relating to ssh-ing into the box.
Everytime I ssh in, I am greeted by the ‘Every 1.0s: cat /boot/first-boot.log’ message that displays about 20 lines of the log ending with the message:
2017-05-15_22:28:53_BST [openHABian] First time boot setup successfully finished.
If I ctrl-c I can get to the command line, but I NEVER see the normal welcome screen. I’ve got all the files I would expect to see - afterfirstboot.lock & openHABian-install-successful.
It doesn’t stop the system working, but it is annoying - any suggestions about how can I fix this?
Could you check the content of /etc/rc.local? I wonder if you’ll find a file with just one-two lines of code. In this case your installation failed at an early stage, I wonder if your setup is benefiting from all openHABian has to offer…
#!/bin/sh -e
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
FLAG="/opt/afterfirstboot.lock"
FIRSTBOOT="/boot/first-boot.sh"
# Only executed after first boot
if [ ! -f "$FLAG" ]; then
echo "[openHABian] Flag file 'afterfirstboot.lock' not found, continuing with '$FIRSTBOOT' script."
if [ ! -f "$FIRSTBOOT" ]; then "[openHABian] 'first-boot.sh' not found, Exiting."; exit 0; fi
if (/bin/bash "$FIRSTBOOT"); then
echo "[openHABian] Created after first boot script succeeded (see /etc/rc.local). Do not delete." > "$FLAG"
modprobe ledtrig_heartbeat
echo "heartbeat" >/sys/class/leds/led0/trigger
else
echo "[openHABian] Script '$FIRSTBOOT' failed."
modprobe ledtrig_timer
echo "timer" >/sys/class/leds/led0/trigger
echo 100 >/sys/class/leds/led0/delay_on
echo 100 >/sys/class/leds/led0/delay_off
fi
fi
exit 0
# vim: filetype=sh
Having moment… I’m guessing I shouldn’t have the extra ‘.’!!
Sorry - been long day already!
Nothing in my .bash_profile, although it does exist.
UPDATE
I ran the command
cat ~/.bash_profile
and although it returned nothing, logging out and back in again now drops me directly to the command line. The first-boot.log no longer shows - so some progress.
I’m guessing that the .bash_profile has been corrupted and is missing vital stuff?
I think so too but that should be easily fixed. Execute sudo openhabian-config, then select “Apply Improvements”, then run all options. The one solving the issue is “Bash&Vim Settings”. Good luck!
