Hi all,
I am using openhabian with pi3 booting from an USB key.
I noticed that the led indicating access to the USB key is almost always on, meaning that the system is continuously writing to the usb key.
So I tried to move the log files to RAM (tmpfs) modifying the file /etc/fstab as follows:
proc /proc proc defaults 0 0
PARTUUID=4f82b826-01 /boot vfat defaults 0 2
PARTUUID=4f82b826-02 / ext4 defaults,noatime 0 1
# a swapfile is not a swap partition, no line here
# use dphys-swapfile swap[on|off] for that
# FOLLOWING TWO LINES ADDED BY ME:
tmpfs /var/log tmpfs nodev,nosuid,size=50M,mode=1777 0 0
tmpfs /tmp tmpfs nodev,nosuid,size=30M,mode=1777 0 0
/usr/share/openhab2 /srv/openhab2-sys none bind 0 0
/etc/openhab2 /srv/openhab2-conf none bind 0 0
/var/lib/openhab2 /srv/openhab2-userdata none bind 0 0
/var/log/openhab2 /srv/openhab2-logs none bind 0 0
/usr/share/openhab2/addons /srv/openhab2-addons none bind 0 0
But unfortunately after this change openhab does not start. I can start the pi3 and login but the status of openhab2 service is as follows:
[22:07:13] openhabian@openHABianPi:~$ systemctl status openhab2
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
Active: deactivating (stop) (Result: exit-code) since Mon 2017-09-11 22:07:19 CEST; 84ms ago
Docs: http://docs.openhab.org
https://community.openhab.org
Process: 5828 ExecStart=/usr/share/openhab2/start.sh server (code=exited, status=255)
Main PID: 5828 (code=exited, status=255); : 5981 (stop)
CGroup: /system.slice/openhab2.service
└─control
├─5981 /bin/sh /usr/share/openhab2/runtime/bin/stop
├─5997 /bin/sh /usr/share/openhab2/runtime/bin/stop
├─5998 /bin/sh /usr/share/openhab2/runtime/bin/stop
├─5999 /bin/sh /usr/share/openhab2/runtime/bin/stop
├─6008 /bin/sh /usr/share/openhab2/runtime/bin/stop
├─6012 /bin/sh /usr/share/openhab2/runtime/bin/stop
├─6015 /bin/sh /usr/share/openhab2/runtime/bin/stop
└─6016 basename /usr/lib/jvm
any idea?
thanks
