Hardware: Raspberry Pi B+
OS: openhabian
openHAB version: 2.40
I had OH2 all set up working with a dozen onewire sensors.
I worked on other programs on the Pi, and updated to the latest using openhabian-config. Then a day or two later I realized it was no longer getting temperatures. The Paper UI showed the onewire binding and items were there to add. but all my names were gone.
Finally went back and updated to the latest onewire binding using the karaf console option at https://janessa.me/esh/org.eclipse.smarthome.binding.onewire-0.10.0-SNAPSHOT-fi.jar and wahlah everything works again!
I think the openhabian-config update actually put an old binding back in.
onewire.things file like this with more things.
Bridge onewire:owserver:mybridge [network-address=“127.0.0.1”]
Thing basic CPURoom [id=“28.3E0943982500”, refresh=60]
Channels: Type temperature-por-res : temperature [resolution=“9”]
The onewire.items file has one line for each item like this
Number:Temperature CPURoom “CPU Room [%.0f %unit%]” { channel=“onewire:basic:mybridge:CPURoom:temperature” }
The onewire.sitemap file like this
sitemap onewire label=“Main Menu”
Frame
Text item=CPURoom
