Platform information:
Rasperry pi 3 + RaZberry z-wave board
openHAB version: Openhabianpi image 2.4.0, recently upgraded to 2.5.0.M1
Issue of the topic: please be detailed explaining your issue
If logs where generated please post these here using code fences:
Openhab was acting more and more strange, yesterday I even had different channels showing in habmin and paper ui. So I decided to try clearing cache, as I had not done that after the upgrade.
Now it’s dead. It says service is running, but nothing in any of the logs, and nothing from debug output. I tried restarting services, also rebooting the pi, several times.
The logs at :9001 work, but there is nothing in the logs since the first reboot after clearing cache.
:8080 is dead
Logs are dead
Services seem to run fine, but there is absolutely zero happening in the logs, and again :8080 not responding. Help ! ?!
A systemd service configuration exists…
Use ‘sudo /bin/systemctl start openhab2.service’ to start an openHAB service
Launching an instance in this terminal…
Launching the openHAB runtime…
Listening for transport dt_socket at address: 5005
What is the output of openhab-cli info? Unfortunately if the behaviour has been getting worse without any input from you, it does sound like a failing SD card.
