I am trying to get the openweathermap binding to work. I am using a openhabian on a raspberry Pi. My OH Version is 2.4.
I am able to install the binding, and I can enter the configuration panel. Here I put in my API-key. I am not sure how to add the String for the location input field - maybe it would be wise to add that to the documentation page. Anyway - can someone verify that the plugin runs under his system or if it is broken. Thanks in advance.
My logs say:
2019-02-03 11:51:47.361 [hingStatusInfoChangedEvent] - âopenweathermap:weather-api:529dd64eâ changed from OFFLINE to UNKNOWN
2019-02-03 11:51:47.372 [me.event.ThingUpdatedEvent] - Thing âopenweathermap:weather-api:529dd64eâ has been updated.
2019-02-03 11:52:02.372 [hingStatusInfoChangedEvent] - âopenweathermap:weather-api:529dd64eâ changed from UNKNOWN to OFFLINE
No - I thought you can only âSearch Thingsâ. Anyway I can see in the binding-documentation that you can add a thing by creating a file. I will give it a try.
Unfortunately there are still problems, when I want to configure the binding. Maybe I made a mistake when I want to give the location to the binding. My entry was â49.4542100,11.0775200â which should be Nuremberg. When I tried to save it in the PaperUI I got some error messages which are related to âConflictsâ. It seems not possible to configure the addon in the file or via PaperUI?! It seems that I am stuck here.
Here are my logs:
2019-02-03 13:59:49.540 [hingStatusInfoChangedEvent] - âopenweathermap:weather-and-forecast:api:miamiâ changed from OFFLINE (CONFIGURATION_ERROR): The location parameter could not be split into latitude and longitude. to UNINITIALIZED
2019-02-03 13:59:49.574 [hingStatusInfoChangedEvent] - âopenweathermap:weather-and-forecast:api:miamiâ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-02-03 13:59:49.588 [hingStatusInfoChangedEvent] - âopenweathermap:weather-api:apiâ changed from OFFLINE (CONFIGURATION_ERROR): The apikey parameter must be configured. to OFFLINE
2019-02-03 13:59:49.748 [hingStatusInfoChangedEvent] - âopenweathermap:weather-and-forecast:api:localâ changed from OFFLINE (CONFIGURATION_ERROR): The location parameter could not be split into latitude and longitude. to UNKNOWN
2019-02-03 13:59:49.806 [me.event.ThingUpdatedEvent] - Thing âopenweathermap:weather-and-forecast:api:localâ has been updated.
2019-02-03 13:59:49.845 [me.event.ThingUpdatedEvent] - Thing âopenweathermap:weather-and-forecast:api:localâ has been updated.
2019-02-03 14:03:27.570 [INFO ] [st.core.internal.thing.ThingResource] - Received HTTP PUT request for update configuration at âthings/openweathermap:weather-api:api/configâ for an unmanaged thing âopenweathermap:weather-api:apiâ.
2019-02-03 14:03:27.578 [INFO ] [st.core.internal.thing.ThingResource] - Received HTTP PUT request for update at âthings/openweathermap:weather-api:apiâ for an unmanaged thing âopenweathermap:weather-api:apiâ.
2019-02-03 14:04:54.713 [INFO ] [st.core.internal.thing.ThingResource] - Received HTTP PUT request for update configuration at âthings/openweathermap:weather-api:api/configâ for an unmanaged thing âopenweathermap:weather-api:apiâ.
2019-02-03 14:04:54.719 [INFO ] [st.core.internal.thing.ThingResource] - Received HTTP PUT request for upd
Same problem here, I have defined it all via text files no paper UI setup at all. It was working but was trying to get the forecast working. Iâm not sure of this broke it or the restart I did, but now cant seem to get it to work. I will keep trying and get back if I get it working. If anyone has any ideas hit me up.
I have it workingâŠ
Not sure if this will help anyone but it was my things file for some reason the lines for local weather and forcast weather as well as the uv index was missing. Added at and it came right online
i have found a solution i like, for habpanel
lob the generated code for image into a custom widget and boom just works.
I then use this binding as now weather only so my hvac rules work as they need current outside temp.
