I’m learning a lot - Openhab is a trial - try to find the docs, finally ask for help process so if there is doc I missed please point me to it. I would like to extend the example in the binding doc to include a map from a second location but I don’t understand how the first one works.
Things
Bridge openweathermap:weather-api:api "OpenWeatherMap Account" [apikey="xyz", ", refreshInterval=30, language="en"] {
Thing weather-and-forecast local "Local Weather And Forecast" [location="39.0483,-95.678", forecastHours=24, forecastDays=0]
Thing weather-and-forecast lw "Lake Weather And Forecast" [location="33.5572,-88.4089", forecastHours=24, forecastDays=0]
Items
sitemap OpenWeather label="OpenWeatherMap" {
Frame label="Local Weather Station" {
Text item=localStationId
Text item=localStationName
Mapview item=localStationLocation
// Local Station Mappings
String localStationId "ID [%s]" { channel="openweathermap:weather-and-forecast:api:local:station#id" }
String localStationName "Name [%s]" { channel="openweathermap:weather-and-forecast:api:local:station#name" }
Location localStationLocation "Location [%2$s°N %3$s°E]" <location> { channel="openweathermap:weather-and-forecast:api:local:station#location" }
I've added and tried several ways to point the map to the coordinates for
//Lake W
Location lwStationLocation "Location [%4$s°N %5$s°E]" <location> { channel="openweathermap:weather-and-forecast:api:local:station#location" }
DateTime lwLastMeasurement "Timestamp of last measurement [%1$tY-%1$tm-%1$tdT%1$tH:%1$tM:%1$tS]" <time> { channel="openweathermap:weather-and-forecast:api:lw:current#time-stamp" }
What is the proper definition for the lwStationLocation to refer to the lw Thing?
