and change the default log level for org.jupnp from ERROR to WARN, I get the following in openhab.log:
2017-01-29 12:32:19.081 [WARN ] [p.protocol.RetrieveRemoteDescriptors] - Device descriptor retrieval failed, no response: http://172.16.13.100:8080/upnp
2017-01-29 12:33:19.085 [WARN ] [p.protocol.RetrieveRemoteDescriptors] - Device descriptor retrieval failed: http://172.16.13.100:8080/upnp, 404 Not Found
2017-01-29 12:34:19.087 [WARN ] [org.jupnp.transport.spi.StreamClient] - HTTP request failed: (StreamRequestMessage) GET http://172.16.13.100:8080/upnp
org.apache.http.NoHttpResponseException: The target server failed to respond
at org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:95)[36:org.apache.httpcomponents.httpclient:4.2.3]
at org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:62)[36:org.apache.httpcomponents.httpclient:4.2.3]
at org.apache.http.impl.io.AbstractMessageParser.parse(AbstractMessageParser.java:254)[37:org.apache.httpcomponents.httpcore:4.2.3]
at org.apache.http.impl.AbstractHttpClientConnection.receiveResponseHeader(AbstractHttpClientConnection.java:289)[37:org.apache.httpcomponents.httpcore:4.2.3]
at org.apache.http.impl.conn.DefaultClientConnection.receiveResponseHeader(DefaultClientConnection.java:252)[36:org.apache.httpcomponents.httpclient:4.2.3]
at org.apache.http.impl.conn.ManagedClientConnectionImpl.receiveResponseHeader(ManagedClientConnectionImpl.java:191)[36:org.apache.httpcomponents.httpclient:4.2.3]
at org.apache.http.protocol.HttpRequestExecutor.doReceiveResponse(HttpRequestExecutor.java:300)[37:org.apache.httpcomponents.httpcore:4.2.3]
at org.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:127)[37:org.apache.httpcomponents.httpcore:4.2.3]
at org.apache.http.impl.client.DefaultRequestDirector.tryExecute(DefaultRequestDirector.java:717)[36:org.apache.httpcomponents.httpclient:4.2.3]
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:522)[36:org.apache.httpcomponents.httpclient:4.2.3]
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:906)[36:org.apache.httpcomponents.httpclient:4.2.3]
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:1066)[36:org.apache.httpcomponents.httpclient:4.2.3]
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:1044)[36:org.apache.httpcomponents.httpclient:4.2.3]
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:1035)[36:org.apache.httpcomponents.httpclient:4.2.3]
at org.jupnp.transport.impl.apache.StreamClientImpl$4.call(StreamClientImpl.java:168)[162:org.jupnp:2.2.0]
at org.jupnp.transport.impl.apache.StreamClientImpl$4.call(StreamClientImpl.java:1)[162:org.jupnp:2.2.0]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_121]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
Ps: I run a Unifi Controller on 8080 & 8443 on the local machine (IP: 172.16.13.100)
Ps2: URL http://172.16.13.100:8081/upnp also gives me 404
Ps3: Everything is working fine (including thing discovery)… this is just a warning that I get which doesn’t seem to affect the functionality of my openHAB 2 system.
I installed OH2 Snapshot #771 on a rPi3 (IP: 172.16.13.101) and I get the same errors in openhab.log (it receives UDP broadcasts from the other host running on IP 172.16.13.100 it seems)
2017-01-30 18:10:21.059 [WARN ] [org.jupnp.transport.spi.StreamClient] - HTTP request failed: (StreamRequestMessage) GET http://172.16.13.100:8080/upnp
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_65]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
2017-01-30 18:10:21.077 [WARN ] [p.protocol.RetrieveRemoteDescriptors] - Device descriptor retrieval failed, no response: http://172.16.13.100:8080/upnp
I don’t even know what org.jupnp does, but something seems to go wrong with it when the HTTP port is changed in a OH2 installation.
Just a note for others who maybe running Unifi Controller (version 5.4.9):
It is a bug in that software. The Unify controller reports that ‘/upnp’ url as a response to SSDP discovery requests, but when it is retrieved it really does return an Apache Tomcat 404 error page.
To disable it: go to the Unifi Controller webpage, in the bottom left there is a pair of gears (settings), then pick ‘Controller’, which has a ‘Controller Settings’ section where you find a ‘Network Discovery’ checkbox. Unchecking that checkbox will make the controller not respond to SSDP discovery requests.
