after updating from 2.3 to 2.4 via apt-get OH didn’t work anymore.
Only Homebuilder and Habpanel is showing on web Basic Ui and PaperUI is not available anymore.
It runs on Raspberry Pi 3 B+
Here’s the log:
2018-12-21 16:50:30.574 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-12-21 16:50:30.586 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Stopped Home Builder
2018-12-21 16:50:30.612 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2018-12-21 16:50:44.462 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-12-21 16:50:44.565 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2018-12-21 16:50:44.888 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Berlin'.
2018-12-21 16:50:54.175 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'dyson455.items'
2018-12-21 16:50:54.539 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'my.items'
2018-12-21 16:50:55.500 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mysql.persist'
2018-12-21 16:51:05.056 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'my.rules'
2018-12-21 16:51:13.826 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'dyson455.rules'
2018-12-21 16:51:14.481 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-12-21 16:51:15.090 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.sitemap'
2018-12-21 16:51:15.145 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'tempsensor.sitemap'
2018-12-21 16:51:15.195 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'dyson455en.sitemap'
2018-12-21 16:51:15.229 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rauchmelder.sitemap'
2018-12-21 16:51:15.643 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ble.things'
2018-12-21 16:51:15.793 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "NumberItem" with key "Buero_Temperature". It exists already from provider "GenericItemProvider"! Failed to add a second with the same UID from provider "ManagedItemProvider"!
2018-12-21 16:51:15.797 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "NumberItem" with key "Buero_Humidity". It exists already from provider "GenericItemProvider"! Failed to add a second with the same UID from provider "ManagedItemProvider"!
2018-12-21 16:51:15.925 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "ItemChannelLink" with key "Buero_Humidity -> mihome:sensor_weather_v1:158d00022884d7:humidity". It exists already from provider "GenericItemChannelLinkProvider"! Failed to add a second with the same UID from provider "ManagedItemChannelLinkProvider"!
2018-12-21 16:51:15.932 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "ItemChannelLink" with key "Buero_Temperature -> mihome:sensor_weather_v1:158d00022884d7:temperature". It exists already from provider "GenericItemChannelLinkProvider"! Failed to add a second with the same UID from provider "ManagedItemChannelLinkProvider"!
2018-12-21 16:51:16.182 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'harmonyhub:hub:HarmonyHub' to inbox.
2018-12-21 16:51:19.160 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.22.22:8080
2018-12-21 16:51:19.163 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.22.22:8443
2018-12-21 16:51:23.236 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'SZSmokeDetectorStatus': The name 'ThingAction' cannot be resolved to an item or type; line 203, column 34, length 11
2018-12-21 16:51:23.242 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'FlurSmokeDetectorStatus': The name 'ThingAction' cannot be resolved to an item or type; line 219, column 34, length 11
2018-12-21 16:51:23.242 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'BueroSmokeDetectorStatus': The name 'ThingAction' cannot be resolved to an item or type; line 211, column 34, length 11
2018-12-21 16:51:23.243 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'WZSmokeDetectorStatus': The name 'ThingAction' cannot be resolved to an item or type; line 194, column 34, length 11
2018-12-21 16:51:23.249 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'FlurSmokeDetectorStatus': The name 'ThingAction' cannot be resolved to an item or type; line 219, column 34, length 11
2018-12-21 16:51:23.256 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'WZSmokeDetectorStatus': The name 'ThingAction' cannot be resolved to an item or type; line 194, column 34, length 11
2018-12-21 16:51:23.266 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'SZSmokeDetectorStatus': The name 'ThingAction' cannot be resolved to an item or type; line 203, column 34, length 11
2018-12-21 16:51:23.265 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'WZSmokeDetectorStatus': The name 'ThingAction' cannot be resolved to an item or type; line 194, column 34, length 11
2018-12-21 16:51:23.264 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'BueroSmokeDetectorStatus': The name 'ThingAction' cannot be resolved to an item or type; line 211, column 34, length 11
2018-12-21 16:51:23.295 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'BueroSmokeDetectorStatus': The name 'ThingAction' cannot be resolved to an item or type; line 211, column 34, length 11
2018-12-21 16:51:23.298 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'SZSmokeDetectorStatus': The name 'ThingAction' cannot be resolved to an item or type; line 203, column 34, length 11
2018-12-21 16:51:23.297 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'FlurSmokeDetectorStatus': The name 'ThingAction' cannot be resolved to an item or type; line 219, column 34, length 11
2018-12-21 16:51:27.524 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule 'CheckSmokeDetectors': The name 'ThingAction' cannot be resolved to an item or type; line 230, column 16, length 11
