Hi @ll,
I am totally new to OH2, formerly used z-way for my home automation.
There’s an issue with Fibaro FGS222 double relay switch. This device has a param #4 which controls the auto-off time for relais 1 in thenths of a second. In OH2 the range of values is limited to 255, which is definitely wrong. The correct range is 0 - 65535. Where can I change that range?
Hi Chris,
thanks.
Besides that this link seems to be broken (error 404): changing the range in a public database changes the value range in my installation?
I think it was just missing the www on the front of the URL - maybe it works now.
The database in the binding comes directly from this online database. Once edited we will generate a new binding with updated information - you’ll need to update the binding then.
Once the binding is updated, if you’re running the snapshot version of the runtime then to update to the latest version you just uninstall and reinstall the binding and it will pick up the latest version. If you’re running the release version then it’s somewhat more complicated so I’d recommend using the snapshot
Z-way-server was instable, but much easier to run. That’s why I am totally confused.
How can I find out if it was the snapshot? I installed the zwave binding via paper ui …
What happens when I reinstall the binding? Will my controller loose all devices so that I would have to include them again? Does OH2 loose all its things?
If you log on to Karaf console (see the docs on how to do this) then you can see the versions with the list command. If you take a look at the docs, I think it is down to what repositories you added to your system.
Ummm - it is restarted just the same as if you restart OH.
I guess I am still not where you wanted to guide me to, but karaf tells me that the whole openHAB stuff including zwave binding is v2.0.0, all the Eclipse stuff is 0.9.0.b4. There’s lots of other stuff of course.
I had a look into the documention but did not find any version history.
Hm, I did the following:
added the openHAB 2 Unstable Repository to my systems apt sources list
I stopped the openhab2 service
sudo apt-get update
sudo apt-get upgrade
I started the service again
I uninstalled and re-installed the zwave binding
Almost everything seems to work fine, but I can’t see any of the changes that I did in your db. Have a look at the screenshots: Zwave version is 2.1.0.SNAPSHOT, but there is still the wrong explanation text for param 4 and the value range ist still 0 - 255. Why?
The most common issue with this sort of thing is that you aren’t really running the latest snapshot, or maybe the package you are using hasn’t been updated recently.
Thanks for the hint, Chris.
The snapshot “openhab.jfrog.io/openhab/openhab-linuxpkg unstable main” hasn’t been updates since 3 days. But as it was newed this morning, I upgraded again and now everything works fine.
Thanks very much for your help. I learned a lot about OH!
