Hi all,
Finally got time to play today - setup MQTT and got basicui working with a few Sonoff devices
Decided to check out HabPanel and after setting up one switch widget (which failed to work) - then going back to BasicUI, nothing works.
Everything looks sane - completely confused!
So cleaned up my code a little (removed the commented out fields) and now the monitor switches work thought the light still will not work although it seems that mqtt gets its state as when i manually turn on the light and then refresh basicUI the switch reports that its now on, very confused!
sitemap home label=“Home”
{Frame label=“Isaacs Room”
{ Switch item=light
Text item=nightlight
Frame label=“Den”
{ Switch item=Power1
Text item=Monitor1
Switch item=Power2
Text item=Monitor2
