I still have a number of proxy items that stay set to NULL on reboot.
I have restoreOnStartup on my persistance configs.
Couple of things Im wondering…
I have 3 persistance bindings - all with restoreOnStartup - could this be conflicting?
I have a script that checks on system start for a switch state of NULL and then if so restore the value from persistance from 1 hour ago, this dosnt seem to work either and thought if the above was working I wouldnt need anyway?
I have 3 persistence services and I only use restore on startup with Mapdb as it stored only the last value anyway. It is useful for this and thing like lastUpdate
I would change to only one persistence-service for restoreOnStartup and only for the items you realy need retoreOnStartup.
For that I think mapdb is the best choise.
I have influxdb to use with grafana to get nice graphs in HABpanel and accurate history
I have rrd4j to make graphs in the sitemaps
and mapdb to restore on start up
You can’t you use Grafana on a sitemap? I must be missunderstanding your statement!
Additionally, the history in rrd4j is “accurate” as well! InfluxDB can compress older data, as well as rrd4j, if you opt to keep all values both databases will keep them as long as desired ( rrd4j not unlimited).
