Hello I’m new on this forum because I couldn’t get access to the cd-jackson database.
I have an CCT wall-controller from sunricher and the corresponding XML but after waiting a couple of weeks to get access I will try to put the XML file here. But unfortunately I couldn’t upload it because I’m a new user so how could I put the XML file in the right place to get support for my device integrated in openhab2?
And second question how do I get the database update after uploading the XML file?
uploaded the XML to the database but couldn’t delete the duplicated command class “security”.
I have to learn a bit more to describe the thing perfect. Some things are unclear to me
My open questions are:
I didn’t know what the “controller” checkmark at the association classes mean.
I didn’t know how to delete the duplicated security command class.
In the datasheet there are a few command classes which I couldn’t find in the dropdown list.
Further I didn’t really know what “Endpoint” mean in this situation.
So is there any documentation/tutorial which explains these things?
Can you edit the text so that it’s properly formatted (remove the end of lines so that the text formats correctly, use the bullets/numbers from the toolbar rather than print them directly into the text - it means it will properly format when exported, otherwise it gets very messy).
It means the binding will associate the group with the controller.
