Yes, it is installed, and uninstalled and reinstalled.
At that moment I see the items getting online
2019-02-06 20:43:21.212 [hingStatusInfoChangedEvent] - 'exec:command:homeeasy' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-02-06 20:43:21.216 [hingStatusInfoChangedEvent] - 'exec:command:homeeasy' changed from INITIALIZING to ONLINE
You are right about the rule, I need to rewrite it (pretty stupid of me and done while writing this reply)
I guess i_home_easy_run.state isn’t getting to OFF, since the exec is failing or hanging. I should try to fix that with a time-out indeed.
That would solve the issues with the rest of the system, but indeed, not with the exec binding.
I do see the trigger in the events log. i_home_easy_arg contains the arguments for the shell script.
2019-02-06 21:24:06.196 [ome.event.ItemCommandEvent] - Item 'i_bovenbed_trigger' received command 50
2019-02-06 21:24:06.204 [vent.ItemStateChangedEvent] - i_bovenbed_trigger changed from 100 to 50
2019-02-06 21:24:09.097 [ome.event.ItemCommandEvent] - Item 'i_home_easy_arg' received command 2660 dimmer 50
2019-02-06 21:24:09.103 [nt.ItemStatePredictedEvent] - i_home_easy_arg predicted to become 2660 dimmer 50
2019-02-06 21:24:09.110 [vent.ItemStateChangedEvent] - i_home_easy_arg changed from 2660 dimmer on to 2660 dimmer 50
I don’t see any specific entries in openhab.log about the exec binding.
