I just made a (third) fresh OH2 + ZWAVE 2 binding install.
ZWAVE binding crashes during start with the error :
> The XML document ‘/ESH-INF/thing/popp_05438_0_0.xml’ in module ‘org.openhab.binding.zwave’ could not be parsed: br : br
---- Debugging information ---- message : br cause-exception : com.thoughtworks.xstream.mapper.CannotResolveClassException cause-message : br class : java.util.ArrayList required-type : java.util.ArrayList converter-type : com.thoughtworks.xstream.converters.collections.CollectionConverter path : /thing-descriptions/thing-type/config-description/parameter[5]/label/br line number : 104 class[1] : org.eclipse.smarthome.config.core.ConfigDescriptionParameter converter-type[1] : org.eclipse.smarthome.config.xml.ConfigDescriptionParameterConverter class[2] : org.eclipse.smarthome.config.core.ConfigDescription converter-type[2] : org.eclipse.smarthome.config.xml.ConfigDescriptionConverter class[3] : org.eclipse.smarthome.core.thing.xml.internal.ThingTypeXmlResult converter-type[3] : org.eclipse.smarthome.core.thing.xml.internal.ThingTypeConverter class[4] : org.eclipse.smarthome.core.thing.xml.internal.ThingDescriptionList converter-type[4] : org.eclipse.smarthome.core.thing.xml.internal.ThingDescriptionConverter version : 1.4.7 -------------------------------
The xml files included in the distribution is incorrect there :
20: Specify the consumption of the load in watts, for the calculation of power**
consumption. Max load 3500 W.
I went to the @chris database site to correct that but the correction has already been done and exported 2016-03-05 23:00:41.
Hopefully, this will be included in next build.
But just in case I post this
