[SOLVED] PostUpdate error
First post here, but I’ve learn so much from lurking and reading for some time. So thanks, to everyone here for your wisdom.
I’ve been setting up my first OpenHab project; a raspberry pi based garage door monitor and controller. Everything is going well, but I’m just having some trouble getting an expire timer/broadcastnotification to work.
I have the following items:
Rollershutter GarageDoorLeft “” <“none”> {http=">[:GET:http://“blahbah”/clk?id=left]"}
Rollershutter GarageDoorRight “” <“none”> {http=">[
:GET:http://“blahblah”/clk?id=right]"}
String GarageDoorLeftStatus “[%s]” {http="<[http://“blahblah”/st?id=right:1000:REGEX((.))]"}
String GarageDoorRightStatus “[%s]” {http="<[http://“blahblah”/st?id=left:1000:REGEX((.
Switch GarageDoorLeftTimer { expire=“5m,command=OFF” }
Switch GarageDoorRightTimer { expire=“5m,command=OFF” }
and the following rules:
rule “Left Garage Door Opened”
Item GarageDoorLeftStatus changed
if (GarageDoorLeftStatus.state == “open”) GarageDoorLeftTimer.sendCommand(ON)
else GarageDoorLeftTimer.PostUpdate(OFF)
rule “Left Garage Door Timer”
Item GarageDoorLeftTimer received command OFF
sendBroadcastNotification (“Bill’s garage door has been open for 5 minutes”)
rule “Right Garage Door Opened”
Item GarageDoorRightStatus changed
if (GarageDoorRightStatus.state == “open”) GarageDoorRightTimer.sendCommand(ON)
else GarageDoorRightTimer.PostUpdate(OFF)
rule “Right Garage Door Timer”
Item GarageDoorRightTimer received command OFF
sendBroadcastNotification (“Janes’s garage door has been open for 5 minutes”)
What I’m trying to do is sendbroadcastnotification when a garage door has remained opened for 5 minutes. When the garage doors open, the sendbroadcastnotifcation triggers 5min after the status change.
The error log indicates the logic might be skipping the PostUpdate as it shows the following error:
2018-09-03 21:02:36.282 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Right Garage Door Opened’: ‘PostUpdate’ is not a member of 'org.$
$‘org.eclipse.smarthome.core.library.items.SwitchItem’; line 6, column 7, length 35
If anyone has any tips it would be enormously appreciated.
postUpdate no capital P
Thanks Vincent! I haven’t had a chance to test the 5m or review the log yet, but I’m not getting spurious notifications, so it looks like that was it. I must have read that code and skimmed over the capital “P” 100 times!
Works perfectly. Thanks again!
You’re welcome
Please mark the thread as solved. Thanks
hc_292
