Recently, i bought a P1 cable for use with the DSMR meter binding. This cable has not arrived yet, but I am already trying this system out with the console. The binding periodically gives me the current usage in kW. I made a rule that changes that to W for use in HABPanel. So far that’s working.
My question now is: how can I convert this to daily usage, and after that change to daily cost. I know there is already a lot of posts regarding this, but after searching for a clear explanation for about an hour I thought i’d ask it in a new post. I already understand that calculating the cost can be easily done using this rule:
val Number kWh_price = 0.2290
rule MeterDailyCost
Item MeterDayUsage changed
MeterDayCost.postUpdate((MeterDayUsage.state as DecimalType) * kWh_price)
I just don’t understand how i can create the MeterDayUsage from the current usage.
You could create a simple rule that triggers at midnight to save the current reading in an item and throughout the day calculate the MeterDayUsage from the delta.
There may be easier ways, but that was the first approach that came to mind.
rule "Midnight DSMR counters persist rule"
Time is midnight
PowerMeterMidnight.postUpdate(PowerMeterTotal.state)
where PowerMeterTotal is the current meter reading (you canreplicate this if you have low/high tariff) and PowerMeterMidnight is the value to save every night. You have to define both Items.
Ok I think i’m starting to understand now.
Will this allow me to calculate Energy Cost during the day, or only the entire day at a time though? My idea was to make a dial or something on HABPanel that says the energy cost so far today.
It seems to have the answer to my question, but since I’m a bit of a noob i can’t seem to make sense of that rules file, because it’s just a big text block. Will it work if i just copy that and change some values? I can make the layout a bit better later.
Okay so I’ve looked farther as is had some more spare time and i have this now:
rule "Daily power usage"
Item MeterActualDeliveryW received update
var long currentTime = now.millis
if (Last_Update !=0) {
var long timeElapsed = currentTime - Last_Update
if (timeElapsed > 0) {
var Number power = MeterActualDeliveryW.state as DecimalType
var Number powerUsage = (power * timeElapsed) / 3600000 / 1000
postUpdate(MeterDayUsage, MeterDayUsage.state as DecimalType + powerUsage)
Last_Update = currentTime
There’s just one problem: it doesn’t work…
I’m going to try putting my logging on a higher level to see what is going wrong.
So i think i got it to work. For anyone interested, here is how i did it.
First i made the rule you can see above. I takes the current wattage reading and does some math to later add it to the MeterDayUsage item.
What made it work was initializing the MeterDayUsage by making a rule that changes it to 0 on system startup.
rule "Energy init"
System started
postUpdate(MeterDayUsage, 0 )
When i did that it magically started working. I now have 2 rules for changing MeterDayUsage to 0, one for initializing and one at midnight, but i will be combining those now.
