I have a lot of false positive. I am on Ubuntu with iputils-arping.
A lot of times my Android phones are online but i am not connected with Wifi. Why it happens?
$ which arping
/usr/sbin/arping
network.cfg
binding.network:allowSystemPings=true
binding.network:allowDHCPlisten=false
binding.network:arpPingToolPath=arping
binding.network:cacheDeviceStateTimeInMS=2000
network.things
Thing network:pingdevice:Smartphone [ hostname="192.168.1.232", timeout=5000, refreshInterval=20000, retry=3 ]
network.items
Group:Switch:AND(OFF,ON) gPresence
Switch Smartphone (gPresence) { channel="network:pingdevice:Smartphone:online" }
log
2019-10-29 08:58:36.037 [GroupItemStateChangedEvent] - gPresence changed from OFF to ON through Smartphone
gPresence changed from OFF to ON through Smartphone but I am not at home, so it is a false positive.
I tried to ping my phone from shell:
$ arping 192.168.1.232
ARPING 192.168.1.232
Timeout
Timeout
Timeout
Timeout
Timeout
Timeout
60 bytes from bb:6f:b4:0b:9a:32 (192.168.1.232): index=0 time=105.648 msec
Timeout
But bb:6f:b4:0b:9a:32 is not the phone and 192.168.1.232 is static assigned by DHCP
In network.cfg try adding uses_arp_pings=yes so file will look like this.
binding,network:cacheDeviceStateTimeInMS=2000
uses_arp_pings=yes
Had to tweek the setting in my things file but this is what I found to work for me.
Things:
Thing network:pingdevice:SiPhone [ hostname="10.0.1.22", uses_ios_wakeup=1, uses_arp_pings=1, retry=30, timeout=15000, refreshInterval=60000 ]
Items:
Group:Switch:AND(OFF,ON) gPresent <present>
Switch Present "Phone is home" <present>
Switch Present_Timer { expire="20m, command=OFF" }
Switch MyDevice <network> (gPresent) { channel="network:pingdevice:SiPhone:online" }
Rule associated with presents detection:
rule "start gPresent on system start"
System started
Present.sendCommand(OFF) // assume no one is home
rule "gPresent updated, at least one change of state"
Item gPresent received update
// someone came home
if(gPresent.state == ON && Present.state != ON) {
Present_Timer.postUpdate(OFF) // cancel the timer if necessary
Present.sendCommand(ON)
// no one is home and timer is not yet ticking (otherwise endless loop)
else if(gPresent.state == OFF && Present.state != OFF && Present_Timer.state != ON) {
Present_Timer.sendCommand(ON) // start the timer
rule "Present_Timer expired"
Item Present_Timer received command OFF
The extra items and rule prevents other things from happening if presents swaps from on to off for a short time e.g. I walk to mail box and loose signal.
I’m trying
binding.network:arpPingToolPath=/bin/ping
and seems to work better
Anyway I prefer Design Pattern: Sensor Aggregation
