[SOLVED] Previousstate in notification rule
i created a notification rule so i get informed, if the price of gasoline at my favorite gas stations changed.
this is working quite good so far, but the last days i had the idea to show the previous price in the notification, too, so i can see if the prices were getting higher or lower:
rule "Spritpreise"
	Item TankstelleHoyerDodenhof_E10 changed or
	Item TankstelleTeamLilienthal_E10 changed or
	Item TankstelleHoyerOttersberg_E10 changed
	if ((Rule_Spritpreise.state == ON) && (nachtmodus.state == OFF)) {
	sendNotification("xxx@yyy.com",
	"Aktuelle E10-Preise:
	Hoyer Dodenhof " +TankstelleHoyerDodenhof_E10.state+ "€ (" +TankstelleHoyerDodenhof_E10.previousState+ "€)
	Hoyer Ottersberg " +TankstelleHoyerOttersberg_E10.state+ "€ (" +TankstelleHoyerOttersberg_E10.previousState+ "€)
	TEAM Lilienthal " +TankstelleTeamLilienthal_E10.state+ "€ (" +TankstelleTeamLilienthal_E10.previousState+ "€)"
the problem is, that i dont get the previous state correctly in the notification - i just get one of the following notifications (i dont know why, but sometimes i get the one and sometimes the other):
can you tell me whats wrong with the rule?
thanks a lot,
Alex
Do you have persistence set up?
yes, i am using mysql as default persistence service and also influxdb as a second service to play a bit around with grafana.
Are these items persisted?
And what does the error log show?
Try changing it to :
TankstelleHoyerDodenhof_E10.previousState.state
thanks! its working with previousState.state!
now i get a number (just with a lot of digits after “,” - can you also tell me how to cut it to 3 digits?)
Based on a previous post , try replacing this:
with this:
(" + String::format("%1$3d", TankstelleHoyerDodenhof_E10.previousState.state) + "€)
thanks for your fast reply, but this doesnt seem to work, i get the following entry in the log:
2018-05-09 21:42:54.102 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Spritpreise': d != org.eclipse.smarthome.core.library.types.DecimalType
Try changing the d for an f
d is for integers
f for floats
(" + String::format("%1$3f", TankstelleHoyerDodenhof_E10.previousState.state) + "€)
tried it out, almost same result:
2018-05-09 21:47:18.310 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Spritpreise': f != org.eclipse.smarthome.core.library.types.DecimalType
"%1$03f"
2018-05-09 21:55:01.195 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Spritpreise': f != org.eclipse.smarthome.core.library.types.DecimalType
"%.3f"
sorry for getting on your nervs, but:
2018-05-09 22:11:48.005 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Spritpreise': f != org.eclipse.smarthome.core.library.types.DecimalType
I was reading the docs but I ran out of ideas now…
ok, but thank you very much for trying to help me!
is it possible that its not working because the item is a number and no string?
No, one of these will work, we just have to find the right one…
...(" + String::format("%1$03f", (TankstelleHoyerDodenhof_E10.previousState.state as DecimalType).floatValue) + "€)...
almost :slight_smile: we are getting closer!
dont mint the UNDEF - this gas station is already closed.
Back to:
"%.3f"
