I am new to openhab and started a few days ago.
I am trying to run TTS using Amazon Echo Control Binding.
Received possive result via PaperUI. Alexa says the text I entered in the UI.
Next I tried to do this via rule resp. command line but this failed.
No error message at command line nor in the event log or openhab2 log.
I am using 2…5.0 M1 release.
command line: WolfgangsEchoPlus_Speak.sendCommand(“a b c d”)
Item is configured:
openhab> smarthome:items list |grep Speak
WolfgangsEchoPlus_SpeakVolume (Type=DimmerItem, State=0, Label=Speak volume, Category=null)
WolfgangsEchoPlus_Speak (Type=StringItem, State=, Label=Speak, Category=null)
What do I need to do to get it running resp. to debug it ?
In http://cubietruck:8080/amazonechocontrol/<Account ID>/ids/?serialNumber=<Echo-Plus-Serial-Number-Here> I see channel bluetootMAC, Channel amazonMusicPlayListId, Channel playAlarmSound, Channel musicProviderId but no further channel.
That is how a command is sent to an item in a DSL rule. I haven’t done this using the karaf console, but according to the documentation here, the correct way would be:
openhab> smarthome:send WolfgangsEchoPlus_Speak 'a b c d'
