Hello everyone, I am using a Fibaro motion sensor for about 2 months now without any problem, today it started acting weird. Once it was detecting motion, he was flashing red instead of green and he did not turn on the lights as usual! Additionally, instead of reacting in the motion rule to turn on the lights, he is turning them on, once tamper is triggered! Also, the rule used to turn the lights off, is not working as expected, its turning the lights off and bringing them back on! Once that happens he will not try to turn them off! Any help appreciated, thanks for your time everyone reading this post in advance!
Best regards John.
Hi John, thanks for the story but we need some hard data to be able to help you. What binding do you use for the sensor? I think that Fibaros are Zwave.
Could you put the Zwave binding in debug mode, please
In the karaf console enter:
log:set DEBUG org.openhab.binding.zwave
Then make your sensor do what it did above motion and tamper blah blahâŠ
Post the log when that happens
Post your rules
Post your items
Hello @vzorglub , the binding I am using is indeed the Z-wave binding. I will need to make three posts to post the entire log.
The log I got from Karaf is the following:
00:08:12.586 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 224 to 225
00:08:12.605 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_AlarmGeneral changed from ON to OFF
00:08:12.611 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 2aa99a9a-993c-4d7a-b7ce-46f08153a8e8 updated: RUNNING
00:08:12.617 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Bedrooms_Lights_Group' received command OFF
00:08:12.632 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 2aa99a9a-993c-4d7a-b7ce-46f08153a8e8 updated: IDLE
00:08:12.647 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Akis_Bedroom_Led_Bulb' received command OFF
00:08:12.657 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Akis_Bedroom_Temperature' received command OFF
00:08:12.675 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Johns_Bulb_Temperature' received command OFF
00:08:12.690 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 225 to 226
00:08:12.704 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Johns_Bedroom_Led_Bulb' received command OFF
00:08:12.727 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Temperature changed from 100 to 0
00:08:12.736 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Akis_Bedroom_Led_Bulb
00:08:12.743 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,80 to 252.9970245361328,0,0
00:08:12.751 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,80 to 0.0,0,0
00:08:12.764 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80.00000000 to 40.00000000 through Akis_Bedroom_Led_Bulb
00:08:12.771 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from ON to OFF through Johns_Bulb_Temperature
00:08:12.779 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bulb_Temperature changed from 100 to 0
00:08:12.785 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Bedrooms_Lights_Brightness' received command 80
00:08:12.788 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 40.00000000 to 0.00000000 through Johns_Bedroom_Led_Bulb
00:08:12.793 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Temperature_Group changed from 100.00000000 to 0.00000000 through Johns_Bulb_Temperature
00:08:12.797 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Akis_Bedroom_Led_Bulb' received command 80
00:08:12.801 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Johns_Bedroom_Led_Bulb' received command 80
00:08:12.816 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,0 to 252.9970245361328,0,80
00:08:12.827 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80 to 40.00000000 through Akis_Bedroom_Led_Bulb
00:08:12.839 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Akis_Bedroom_Led_Bulb
00:08:12.850 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 40.00000000 to 80.00000000 through Johns_Bedroom_Led_Bulb
00:08:12.859 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,0 to 0.0,0,80
00:08:12.878 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Bedrooms_Lights_Brightness' received command 80
00:08:12.886 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Akis_Bedroom_Led_Bulb' received command 80
00:08:12.904 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Johns_Bedroom_Led_Bulb' received command 80
00:08:16.189 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:07:16 EEST to 2018-05-23 00:08:16 EEST
00:08:43.358 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 226 to 227
00:08:43.367 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_BinarySensor changed from ON to OFF
00:08:43.390 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 227 to 228
00:08:43.519 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 228 to 229
00:08:43.554 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 229 to 230
00:08:44.819 [INFO ] [smarthome.event.RuleUpdatedEvent ] - Rule '2aa99a9a-993c-4d7a-b7ce-46f08153a8e8' has been updated.
00:08:44.841 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 2aa99a9a-993c-4d7a-b7ce-46f08153a8e8 updated: INITIALIZING
00:08:44.861 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 2aa99a9a-993c-4d7a-b7ce-46f08153a8e8 updated: IDLE
00:08:46.579 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 2aa99a9a-993c-4d7a-b7ce-46f08153a8e8 updated: RUNNING
00:08:46.585 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Bedrooms_Lights_Group' received command OFF
00:08:46.591 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 2aa99a9a-993c-4d7a-b7ce-46f08153a8e8 updated: IDLE
00:08:46.594 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Akis_Bedroom_Led_Bulb' received command OFF
00:08:46.602 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Akis_Bedroom_Temperature' received command OFF
00:08:46.607 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Johns_Bulb_Temperature' received command OFF
00:08:46.615 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Johns_Bedroom_Led_Bulb' received command OFF
00:08:46.649 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,80 to 252.9970245361328,0,0
00:08:46.654 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Akis_Bedroom_Temperature
00:08:46.659 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80.00000000 to 40.00000000 through Akis_Bedroom_Led_Bulb
00:08:46.667 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,80 to 0.0,0,0
00:08:46.674 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from ON to OFF through Johns_Bedroom_Led_Bulb
00:08:46.678 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 40.00000000 to 0.00000000 through Johns_Bedroom_Led_Bulb
00:08:48.286 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 230 to 231
00:08:48.292 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_BinarySensor changed from OFF to ON
00:08:48.315 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 231 to 232
00:08:48.439 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 232 to 233
00:08:48.481 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 233 to 234
00:09:16.194 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:08:16 EEST to 2018-05-23 00:09:16 EEST
00:09:18.286 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 234 to 235
00:09:18.298 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_BinarySensor changed from ON to OFF
00:09:18.326 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 235 to 236
00:09:18.453 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 236 to 237
00:09:18.489 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 237 to 238
00:10:16.199 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:09:16 EEST to 2018-05-23 00:10:16 EEST
00:11:16.207 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:10:16 EEST to 2018-05-23 00:11:16 EEST
00:12:16.214 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:11:16 EEST to 2018-05-23 00:12:16 EEST
00:13:16.220 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:12:16 EEST to 2018-05-23 00:13:16 EEST
00:14:16.223 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:13:16 EEST to 2018-05-23 00:14:16 EEST
00:15:16.228 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:14:16 EEST to 2018-05-23 00:15:16 EEST
00:16:16.241 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:15:16 EEST to 2018-05-23 00:16:16 EEST
00:17:16.288 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'ntp:ntp:local' changed from OFFLINE (COMMUNICATION_ERROR): The network connection to the timeserver 0.pool.ntp.org cannot be established -> returning current sytem time instead. to ONLINE
00:17:16.300 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:16:16 EEST to 2018-05-23 00:17:16 EEST
00:18:16.300 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:17:16 EEST to 2018-05-23 00:18:16 EEST
00:19:16.306 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:18:16 EEST to 2018-05-23 00:19:16 EEST
00:20:16.312 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:19:16 EEST to 2018-05-23 00:20:16 EEST
00:21:16.316 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:20:16 EEST to 2018-05-23 00:21:16 EEST
00:22:16.325 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:21:16 EEST to 2018-05-23 00:22:16 EEST
00:23:16.329 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:22:16 EEST to 2018-05-23 00:23:16 EEST
00:24:16.334 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:23:16 EEST to 2018-05-23 00:24:16 EEST
00:25:16.346 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:24:16 EEST to 2018-05-23 00:25:16 EEST
00:26:16.349 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:25:16 EEST to 2018-05-23 00:26:16 EEST
00:27:16.354 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:26:16 EEST to 2018-05-23 00:27:16 EEST
00:28:16.364 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:27:16 EEST to 2018-05-23 00:28:16 EEST
00:29:16.369 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:28:16 EEST to 2018-05-23 00:29:16 EEST
00:30:16.372 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:29:16 EEST to 2018-05-23 00:30:16 EEST
00:31:16.386 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:30:16 EEST to 2018-05-23 00:31:16 EEST
00:32:16.387 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:31:16 EEST to 2018-05-23 00:32:16 EEST
00:33:16.395 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:32:16 EEST to 2018-05-23 00:33:16 EEST
00:34:16.413 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:33:16 EEST to 2018-05-23 00:34:16 EEST
00:35:16.415 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:34:16 EEST to 2018-05-23 00:35:16 EEST
00:36:16.422 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:35:16 EEST to 2018-05-23 00:36:16 EEST
00:37:16.426 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:36:16 EEST to 2018-05-23 00:37:16 EEST
00:37:36.870 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 238 to 239
00:37:36.887 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_BinarySensor changed from OFF to ON
00:37:36.910 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 239 to 240
00:37:37.038 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 240 to 241
00:37:37.070 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 241 to 242
00:37:42.600 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 242 to 243
00:37:42.616 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_TamperAlarm changed from OFF to ON
00:37:42.639 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 243 to 244
00:37:42.771 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 244 to 245
00:37:42.789 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_AlarmGeneral changed from OFF to ON
00:37:42.807 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 83d2c96a-2fe2-4942-a6c2-b6207a5e69fe updated: RUNNING
00:37:42.812 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Bedrooms_Lights_Group' received command ON
00:37:42.846 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 83d2c96a-2fe2-4942-a6c2-b6207a5e69fe updated: IDLE
00:37:42.865 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Akis_Bedroom_Led_Bulb' received command ON
00:37:42.872 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 245 to 246
00:37:42.877 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Akis_Bedroom_Temperature' received command ON
00:37:42.884 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Johns_Bulb_Temperature' received command ON
00:37:42.888 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Johns_Bedroom_Led_Bulb' received command ON
00:37:42.918 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Temperature_Group changed from 0.00000000 to 100.00000000 through Akis_Bedroom_Temperature
00:37:42.934 [WARN ] [ipse.smarthome.core.items.GenericItem] - failed notifying listener 'Bedrooms_Lights_Temperature_Group (Type=GroupItem, BaseType=DimmerItem, Members=2, State=100.00000000, Label=Bedrooms Light Temperature, Category=Slider)' about state update of item Johns_Bulb_Temperature: Value must be between 0 and 100
java.lang.IllegalArgumentException: Value must be between 0 and 100
at org.eclipse.smarthome.core.library.types.PercentType.validateValue(PercentType.java:55) [109:org.eclipse.smarthome.core:0.10.0.b1]
at org.eclipse.smarthome.core.library.types.PercentType.<init>(PercentType.java:50) [109:org.eclipse.smarthome.core:0.10.0.b1]
at org.eclipse.smarthome.core.library.types.DecimalType.as(DecimalType.java:158) [109:org.eclipse.smarthome.core:0.10.0.b1]
at org.eclipse.smarthome.core.items.ItemUtil.convertToAcceptedState(ItemUtil.java:92) [109:org.eclipse.smarthome.core:0.10.0.b1]
at org.eclipse.smarthome.core.items.GroupItem.stateUpdated(GroupItem.java:348) [109:org.eclipse.smarthome.core:0.10.0.b1]
at org.eclipse.smarthome.core.items.GenericItem$1.run(GenericItem.java:232) [109:org.eclipse.smarthome.core:0.10.0.b1]
00:37:42.956 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Temperature changed from 0 to 100
00:37:42.960 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,0 to 252.9970245361328,0,100
00:37:42.965 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 0.00000000 to 50.00000000 through Akis_Bedroom_Led_Bulb
00:37:42.970 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bulb_Temperature changed from 0 to 100
00:37:42.973 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,0 to 0.0,0,100
00:37:42.982 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 50.00000000 to 100.00000000 through Johns_Bedroom_Led_Bulb
00:37:42.987 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Bedrooms_Lights_Brightness' received command 80
00:37:42.999 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Akis_Bedroom_Led_Bulb' received command 80
00:37:43.007 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Johns_Bedroom_Led_Bulb' received command 80
00:37:43.064 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80 to 90.00000000 through Akis_Bedroom_Led_Bulb
00:37:43.068 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,100 to 252.9970245361328,0,80
00:37:43.075 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 90.00000000 to 80.00000000 through Johns_Bedroom_Led_Bulb
00:37:43.080 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,100 to 0.0,0,80
00:38:13.010 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 246 to 247
00:38:13.033 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_TamperAlarm changed from ON to OFF
00:38:13.057 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 247 to 248
00:38:13.184 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 248 to 249
00:38:13.200 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_AlarmGeneral changed from ON to OFF
00:38:13.205 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 2aa99a9a-993c-4d7a-b7ce-46f08153a8e8 updated: RUNNING
00:38:13.211 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Bedrooms_Lights_Group' received command OFF
00:38:13.215 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 2aa99a9a-993c-4d7a-b7ce-46f08153a8e8 updated: IDLE
00:38:13.247 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Akis_Bedroom_Led_Bulb' received command OFF
00:38:13.274 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Akis_Bedroom_Temperature' received command OFF
00:38:13.290 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Johns_Bulb_Temperature' received command OFF
00:38:13.320 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 249 to 250
00:38:13.323 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Johns_Bedroom_Led_Bulb' received command OFF
00:38:13.335 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,80 to 252.9970245361328,0,0
00:38:13.349 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Temperature changed from 100 to 0
00:38:13.353 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bulb_Temperature changed from 100 to 0
00:38:13.357 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80.00000000 to 40.00000000 through Akis_Bedroom_Led_Bulb
00:38:13.362 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Akis_Bedroom_Led_Bulb
00:38:13.377 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Temperature_Group changed from 100.00000000 to 0.00000000 through Johns_Bulb_Temperature
00:38:13.385 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Bedrooms_Lights_Brightness' received command 80
00:38:13.393 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,80 to 0.0,0,0
00:38:13.402 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Akis_Bedroom_Led_Bulb' received command 80
00:38:13.412 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Johns_Bedroom_Led_Bulb' received command 80
00:38:13.480 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from ON to OFF through Johns_Bedroom_Led_Bulb
00:38:13.494 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 40.00000000 to 0.00000000 through Johns_Bedroom_Led_Bulb
00:38:13.518 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Akis_Bedroom_Led_Bulb
00:38:13.524 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,0 to 252.9970245361328,0,80
00:38:13.538 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80 to 40.00000000 through Akis_Bedroom_Led_Bulb
00:38:13.558 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 40.00000000 to 80.00000000 through Johns_Bedroom_Led_Bulb
00:38:13.562 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,0 to 0.0,0,80
00:38:13.582 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Bedrooms_Lights_Brightness' received command 80
00:38:13.597 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Akis_Bedroom_Led_Bulb' received command 80
00:38:13.606 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Johns_Bedroom_Led_Bulb' received command 80
00:38:16.428 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:37:16 EEST to 2018-05-23 00:38:16 EEST
00:38:56.926 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 250 to 251
00:38:56.940 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_BinarySensor changed from ON to OFF
00:38:56.963 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 251 to 252
00:38:57.095 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 252 to 253
00:38:57.129 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 253 to 254
00:39:16.433 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:38:16 EEST to 2018-05-23 00:39:16 EEST
00:40:16.442 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:39:16 EEST to 2018-05-23 00:40:16 EEST
00:41:16.441 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:40:16 EEST to 2018-05-23 00:41:16 EEST
00:42:16.446 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:41:16 EEST to 2018-05-23 00:42:16 EEST
00:43:16.450 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:42:16 EEST to 2018-05-23 00:43:16 EEST
00:44:16.458 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:43:16 EEST to 2018-05-23 00:44:16 EEST
00:45:16.463 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:44:16 EEST to 2018-05-23 00:45:16 EEST
00:46:16.474 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:45:16 EEST to 2018-05-23 00:46:16 EEST
00:47:16.475 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:46:16 EEST to 2018-05-23 00:47:16 EEST
00:48:16.533 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:47:16 EEST to 2018-05-23 00:48:16 EEST
00:49:16.537 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:48:16 EEST to 2018-05-23 00:49:16 EEST
00:50:16.543 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:49:16 EEST to 2018-05-23 00:50:16 EEST
00:51:16.549 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:50:16 EEST to 2018-05-23 00:51:16 EEST
00:52:16.556 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:51:16 EEST to 2018-05-23 00:52:16 EEST
00:53:16.563 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:52:16 EEST to 2018-05-23 00:53:16 EEST
00:54:16.573 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:53:16 EEST to 2018-05-23 00:54:16 EEST
00:55:16.578 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:54:16 EEST to 2018-05-23 00:55:16 EEST
00:56:16.583 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:55:16 EEST to 2018-05-23 00:56:16 EEST
00:57:16.593 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:56:16 EEST to 2018-05-23 00:57:16 EEST
00:58:16.595 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:57:16 EEST to 2018-05-23 00:58:16 EEST
00:59:16.602 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:58:16 EEST to 2018-05-23 00:59:16 EEST
01:00:16.610 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 00:59:16 EEST to 2018-05-23 01:00:16 EEST
01:01:16.613 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 01:00:16 EEST to 2018-05-23 01:01:16 EEST
01:02:16.621 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 01:01:16 EEST to 2018-05-23 01:02:16 EEST
01:03:16.631 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 01:02:16 EEST to 2018-05-23 01:03:16 EEST
01:03:38.428 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 254 to 255
01:03:38.447 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_BinarySensor changed from OFF to ON
01:03:38.470 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 255 to 256
01:03:38.593 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 256 to 257
01:03:38.633 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 257 to 258
01:04:16.612 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 258 to 259
01:04:16.626 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_TamperAlarm changed from OFF to ON
01:04:16.654 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 01:03:16 EEST to 2018-05-23 01:04:16 EEST
01:04:16.681 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 259 to 260
01:04:16.778 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 260 to 261
01:04:16.801 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_AlarmGeneral changed from OFF to ON
01:04:16.814 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 83d2c96a-2fe2-4942-a6c2-b6207a5e69fe updated: RUNNING
01:04:16.831 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Groupâ received command ON
01:04:16.857 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command ON
01:04:16.860 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 83d2c96a-2fe2-4942-a6c2-b6207a5e69fe updated: IDLE
01:04:16.907 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Temperatureâ received command ON
01:04:16.912 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 261 to 262
01:04:16.923 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bulb_Temperatureâ received command ON
01:04:16.930 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command ON
01:04:16.988 [WARN ] [ipse.smarthome.core.items.GenericItem] - failed notifying listener âBedrooms_Lights_Temperature_Group (Type=GroupItem, BaseType=DimmerItem, Members=2, State=100.00000000, Label=Bedrooms Light Temperature, Category=Slider)â about state update of item Johns_Bulb_Temperature: Value must be between 0 and 100
at org.eclipse.smarthome.core.library.types.PercentType.(PercentType.java:50) [109:org.eclipse.smarthome.core:0.10.0.b1]
01:04:17.007 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,80 to 252.9970245361328,0,100
01:04:17.048 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,80 to 0.0,0,100
01:04:17.063 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80.00000000 to 90.00000000 through Akis_Bedroom_Led_Bulb
01:04:17.068 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Temperature_Group changed from 0.00000000 to 100.00000000 through Akis_Bedroom_Temperature
01:04:17.073 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bulb_Temperature changed from 0 to 100
01:04:17.081 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 90.00000000 to 100.00000000 through Johns_Bedroom_Led_Bulb
01:04:17.089 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Temperature changed from 0 to 100
01:04:17.897 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,100 to 252.9970245361328,0,65
01:04:17.902 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 100.00000000 to 82.50000000 through Akis_Bedroom_Led_Bulb
01:04:18.075 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 82.50000000 to 65.00000000 through Johns_Bedroom_Led_Bulb
01:04:18.092 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,100 to 0.0,0,65
01:04:47.470 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 262 to 263
01:04:47.489 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_TamperAlarm changed from ON to OFF
01:04:47.507 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 263 to 264
01:04:47.641 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 264 to 265
01:04:47.664 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_AlarmGeneral changed from ON to OFF
01:04:47.670 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 2aa99a9a-993c-4d7a-b7ce-46f08153a8e8 updated: RUNNING
01:04:47.688 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Groupâ received command OFF
01:04:47.700 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command OFF
01:04:47.711 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 2aa99a9a-993c-4d7a-b7ce-46f08153a8e8 updated: IDLE
01:04:47.717 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Temperatureâ received command OFF
01:04:47.727 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bulb_Temperatureâ received command OFF
01:04:47.738 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command OFF
01:04:47.777 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 265 to 266
01:04:47.810 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,65 to 0.0,0,0
01:04:47.822 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Temperature changed from 100 to 0
01:04:47.830 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Johns_Bedroom_Led_Bulb
01:04:47.842 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,65 to 252.9970245361328,0,0
01:04:47.858 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bulb_Temperature changed from 100 to 0
01:04:47.863 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 65.00000000 to 32.50000000 through Johns_Bedroom_Led_Bulb
01:04:47.871 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from ON to OFF through Akis_Bedroom_Led_Bulb
01:04:47.879 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 32.50000000 to 0.00000000 through Akis_Bedroom_Led_Bulb
01:04:47.886 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Temperature_Group changed from 100.00000000 to 0.00000000 through Akis_Bedroom_Temperature
01:05:16.647 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 01:04:16 EEST to 2018-05-23 01:05:16 EEST
01:05:24.403 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 266 to 267
01:05:24.411 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_BinarySensor changed from ON to OFF
01:05:24.440 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 267 to 268
01:05:24.560 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 268 to 269
01:05:24.614 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 269 to 270
01:06:16.651 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 01:05:16 EEST to 2018-05-23 01:06:16 EEST
01:07:16.657 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 01:06:16 EEST to 2018-05-23 01:07:16 EEST
01:08:16.671 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 01:07:16 EEST to 2018-05-23 01:08:16 EEST
01:09:12.150 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 270 to 271
01:09:12.163 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_BinarySensor changed from OFF to ON
01:09:12.183 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 271 to 272
01:09:12.310 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 272 to 273
01:09:12.346 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 273 to 274
01:09:14.045 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 4 to 3
01:09:16.672 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 01:08:16 EEST to 2018-05-23 01:09:16 EEST
01:09:29.306 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 3 to 4
01:09:34.266 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 274 to 275
01:09:34.292 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_TamperAlarm changed from OFF to ON
01:09:34.311 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 275 to 276
01:09:34.457 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 276 to 277
01:09:34.470 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_AlarmGeneral changed from OFF to ON
01:09:34.483 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 83d2c96a-2fe2-4942-a6c2-b6207a5e69fe updated: RUNNING
01:09:34.496 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Groupâ received command ON
01:09:34.510 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 277 to 278
01:09:34.523 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 83d2c96a-2fe2-4942-a6c2-b6207a5e69fe updated: IDLE
01:09:34.549 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command ON
01:09:34.578 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Temperatureâ received command ON
01:09:34.590 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bulb_Temperatureâ received command ON
01:09:34.633 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 0.00000000 to 50.00000000 through Akis_Bedroom_Led_Bulb
01:09:34.643 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command ON
01:09:34.653 [WARN ] [ipse.smarthome.core.items.GenericItem] - failed notifying listener âBedrooms_Lights_Temperature_Group (Type=GroupItem, BaseType=DimmerItem, Members=2, State=100.00000000, Label=Bedrooms Light Temperature, Category=Slider)â about state update of item Johns_Bulb_Temperature: Value must be between 0 and 100
01:09:34.682 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,0 to 252.9970245361328,0,100
01:09:34.688 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Temperature changed from 0 to 100
01:09:34.699 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bulb_Temperature changed from 0 to 100
01:09:34.704 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Temperature_Group changed from 0.00000000 to 100.00000000 through Akis_Bedroom_Temperature
01:09:34.742 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Brightnessâ received command 80
01:09:34.755 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,0 to 0.0,0,100
01:09:34.761 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 50.00000000 to 100.00000000 through Johns_Bedroom_Led_Bulb
01:09:34.777 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command 80
01:09:34.789 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command 80
01:09:34.853 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80 to 90.00000000 through Akis_Bedroom_Led_Bulb
01:09:34.864 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,100 to 252.9970245361328,0,80
01:09:34.871 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 90.00000000 to 80.00000000 through Johns_Bedroom_Led_Bulb
01:09:34.877 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,100 to 0.0,0,80
01:09:35.410 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 4 to 3
01:09:38.468 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 3 to 4
01:09:59.184 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 278 to 279
01:09:59.200 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_BinarySensor changed from ON to OFF
01:09:59.235 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 279 to 280
01:09:59.364 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 280 to 281
01:09:59.398 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 281 to 282
01:10:05.201 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 282 to 283
01:10:05.221 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_TamperAlarm changed from ON to OFF
01:10:05.245 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 283 to 284
01:10:05.374 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 284 to 285
01:10:05.393 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_AlarmGeneral changed from ON to OFF
01:10:05.425 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 2aa99a9a-993c-4d7a-b7ce-46f08153a8e8 updated: RUNNING
01:10:05.433 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Groupâ received command OFF
01:10:05.448 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 285 to 286
01:10:05.468 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 2aa99a9a-993c-4d7a-b7ce-46f08153a8e8 updated: IDLE
01:10:05.475 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command OFF
01:10:05.504 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Temperatureâ received command OFF
01:10:05.509 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bulb_Temperatureâ received command OFF
01:10:05.517 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command OFF
01:10:05.531 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,80 to 252.9970245361328,0,0
01:10:05.540 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Akis_Bedroom_Led_Bulb
01:10:05.553 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80.00000000 to 40.00000000 through Akis_Bedroom_Led_Bulb
01:10:05.590 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Temperature changed from 100 to 0
01:10:05.599 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 40.00000000 to 0.00000000 through Johns_Bedroom_Led_Bulb
01:10:05.606 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,80 to 0.0,0,0
01:10:05.624 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Brightnessâ received command 80
01:10:05.630 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Temperature_Group changed from 100.00000000 to 0.00000000 through Johns_Bulb_Temperature
01:10:05.638 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from ON to OFF through Johns_Bulb_Temperature
01:10:05.670 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bulb_Temperature changed from 100 to 0
01:10:05.681 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command 80
01:10:05.685 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command 80
01:10:05.696 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,0 to 252.9970245361328,0,80
01:10:05.704 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80 to 40.00000000 through Akis_Bedroom_Led_Bulb
01:10:05.708 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Akis_Bedroom_Led_Bulb
01:10:05.712 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,0 to 0.0,0,80
01:10:05.721 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 40.00000000 to 80.00000000 through Johns_Bedroom_Led_Bulb
01:10:05.748 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Brightnessâ received command 80
01:10:05.765 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command 80
01:10:05.788 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command 80
01:10:12.014 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Groupâ received command OFF
01:10:12.032 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command OFF
01:10:12.037 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Temperatureâ received command OFF
01:10:12.113 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bulb_Temperatureâ received command OFF
01:10:12.117 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command OFF
01:10:12.143 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,80 to 252.9970245361328,0,0
01:10:12.157 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Akis_Bedroom_Led_Bulb
01:10:12.173 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80.00000000 to 40.00000000 through Akis_Bedroom_Led_Bulb
01:10:12.217 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Brightnessâ received command 80
01:10:12.221 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,80 to 0.0,0,0
01:10:12.224 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 40.00000000 to 0.00000000 through Johns_Bedroom_Led_Bulb
01:10:12.227 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command 80
01:10:12.241 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command 80
01:10:12.249 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from ON to OFF through Johns_Bedroom_Led_Bulb
01:10:12.293 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,0 to 252.9970245361328,0,80
01:10:12.298 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80 to 40.00000000 through Akis_Bedroom_Led_Bulb
01:10:12.302 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Akis_Bedroom_Led_Bulb
01:10:12.305 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 40.00000000 to 80.00000000 through Johns_Bedroom_Led_Bulb
01:10:12.310 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,0 to 0.0,0,80
01:10:12.370 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Brightnessâ received command 80
01:10:12.387 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command 80
01:10:12.397 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command 80
01:10:12.938 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Groupâ received command OFF
01:10:12.945 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command OFF
01:10:12.950 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Temperatureâ received command OFF
01:10:12.982 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bulb_Temperatureâ received command OFF
01:10:12.991 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command OFF
01:10:13.035 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,80 to 252.9970245361328,0,0
01:10:13.104 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80.00000000 to 40.00000000 through Akis_Bedroom_Led_Bulb
01:10:13.112 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Akis_Bedroom_Led_Bulb
01:10:13.116 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from ON to OFF through Johns_Bedroom_Led_Bulb
01:10:13.121 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,80 to 0.0,0,0
01:10:13.125 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Brightnessâ received command 80
01:10:13.140 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 40.00000000 to 0.00000000 through Johns_Bedroom_Led_Bulb
01:10:13.151 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command 80
01:10:13.160 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command 80
01:10:13.226 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,0 to 0.0,0,80
01:10:13.249 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80 to 40.00000000 through Johns_Bedroom_Led_Bulb
01:10:13.255 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,0 to 252.9970245361328,0,80
01:10:13.259 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Johns_Bedroom_Led_Bulb
01:10:13.264 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 40.00000000 to 80.00000000 through Akis_Bedroom_Led_Bulb
01:10:13.305 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Groupâ received command OFF
01:10:13.310 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command OFF
01:10:13.321 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Temperatureâ received command OFF
01:10:13.336 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bulb_Temperatureâ received command OFF
01:10:13.369 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command OFF
01:10:13.381 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,80 to 252.9970245361328,0,0
01:10:13.391 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80.00000000 to 40.00000000 through Akis_Bedroom_Led_Bulb
01:10:13.394 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Akis_Bedroom_Led_Bulb
01:10:13.459 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 40.00000000 to 0.00000000 through Johns_Bedroom_Led_Bulb
01:10:13.462 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,80 to 0.0,0,0
01:10:13.471 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from ON to OFF through Johns_Bedroom_Led_Bulb
01:10:13.481 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Brightnessâ received command 80
01:10:13.485 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command 80
01:10:13.520 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command 80
01:10:13.553 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Akis_Bedroom_Led_Bulb
01:10:13.559 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,0 to 252.9970245361328,0,80
01:10:13.583 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 0.00000000 to 40.00000000 through Akis_Bedroom_Led_Bulb
01:10:13.599 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,0 to 0.0,0,80
01:10:13.612 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Brightnessâ received command 80
01:10:13.633 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command 80
01:10:13.649 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command 80
01:10:14.135 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Groupâ received command OFF
01:10:14.143 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command OFF
01:10:14.176 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Temperatureâ received command OFF
01:10:14.187 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bulb_Temperatureâ received command OFF
01:10:14.199 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command OFF
01:10:14.240 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80.00000000 to 40.00000000 through Akis_Bedroom_Led_Bulb
01:10:14.255 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,80 to 252.9970245361328,0,0
01:10:14.291 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Akis_Bedroom_Led_Bulb
01:10:14.298 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from ON to OFF through Johns_Bedroom_Led_Bulb
01:10:14.303 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,80 to 0.0,0,0
01:10:14.309 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 40.00000000 to 0.00000000 through Johns_Bedroom_Led_Bulb
01:10:16.676 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 01:09:16 EEST to 2018-05-23 01:10:16 EEST
01:10:33.003 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 4 to 3
01:10:36.061 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 3 to 4
01:10:45.222 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 4 to 3
01:11:16.683 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 01:10:16 EEST to 2018-05-23 01:11:16 EEST
01:11:24.094 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 286 to 287
01:11:24.101 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_BinarySensor changed from OFF to ON
01:11:24.122 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 287 to 288
01:11:24.257 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 288 to 289
01:11:24.288 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 289 to 290
01:11:24.902 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 3 to 4
01:11:27.953 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 4 to 3
01:11:54.139 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 290 to 291
01:11:57.366 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_BinarySensor changed from ON to OFF
01:11:57.370 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 291 to 292
01:11:57.373 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 292 to 293
01:11:57.379 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 293 to 294
01:12:16.687 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 01:11:16 EEST to 2018-05-23 01:12:16 EEST
01:12:16.791 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 3 to 4
01:12:22.913 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 4 to 3
01:12:25.959 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 3 to 4
01:12:29.008 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 4 to 3
01:12:32.058 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 3 to 4
01:12:35.111 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 4 to 3
01:13:16.694 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 01:12:16 EEST to 2018-05-23 01:13:16 EEST
01:13:23.383 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 294 to 295
01:13:23.397 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_TamperAlarm changed from OFF to ON
01:13:23.428 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 295 to 296
01:13:23.546 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 296 to 297
01:13:23.562 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_AlarmGeneral changed from OFF to ON
01:13:23.567 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 83d2c96a-2fe2-4942-a6c2-b6207a5e69fe updated: RUNNING
01:13:23.575 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Groupâ received command ON
01:13:23.578 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command ON
01:13:23.582 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 83d2c96a-2fe2-4942-a6c2-b6207a5e69fe updated: IDLE
01:13:23.607 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Temperatureâ received command ON
01:13:23.621 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bulb_Temperatureâ received command ON
01:13:23.630 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command ON
01:13:23.665 [WARN ] [ipse.smarthome.core.items.GenericItem] - failed notifying listener âBedrooms_Lights_Temperature_Group (Type=GroupItem, BaseType=DimmerItem, Members=2, State=100.00000000, Label=Bedrooms Light Temperature, Category=Slider)â about state update of item Akis_Bedroom_Temperature: Value must be between 0 and 100
01:13:23.690 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bulb_Temperature changed from 0 to 100
01:13:23.696 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,0 to 252.9970245361328,0,100
01:13:23.702 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Temperature changed from 0 to 100
01:13:23.708 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 297 to 298
01:13:23.729 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,0 to 0.0,0,100
01:13:23.736 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Temperature_Group changed from 0.00000000 to 100.00000000 through Johns_Bulb_Temperature
01:13:23.768 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 50.00000000 to 100.00000000 through Johns_Bedroom_Led_Bulb
01:13:23.785 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 0.00000000 to 50.00000000 through Akis_Bedroom_Led_Bulb
01:13:23.790 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Brightnessâ received command 80
01:13:23.796 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command 80
01:13:23.812 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command 80
01:13:23.866 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,100 to 252.9970245361328,0,80
01:13:23.882 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80 to 90.00000000 through Akis_Bedroom_Led_Bulb
01:13:23.892 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,100 to 0.0,0,80
01:13:23.901 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 90.00000000 to 80.00000000 through Johns_Bedroom_Led_Bulb
01:13:23.975 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 3 to 4
01:13:24.568 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 298 to 299
01:13:24.579 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_BinarySensor changed from OFF to ON
01:13:24.605 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 299 to 300
01:13:24.732 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 300 to 301
01:13:24.772 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 301 to 302
01:13:27.005 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 4 to 3
01:13:39.215 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 3 to 4
01:13:45.319 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 4 to 3
01:13:51.418 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 3 to 4
01:13:54.027 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 302 to 303
01:13:54.050 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_TamperAlarm changed from ON to OFF
01:13:54.075 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 303 to 304
01:13:54.204 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 304 to 305
01:13:54.221 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_AlarmGeneral changed from ON to OFF
01:13:54.228 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 2aa99a9a-993c-4d7a-b7ce-46f08153a8e8 updated: RUNNING
01:13:54.247 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âBedrooms_Lights_Groupâ received command OFF
01:13:54.253 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Led_Bulbâ received command OFF
01:13:54.258 [INFO ] [smarthome.event.RuleStatusInfoEvent ] - 2aa99a9a-993c-4d7a-b7ce-46f08153a8e8 updated: IDLE
01:13:54.272 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âAkis_Bedroom_Temperatureâ received command OFF
01:13:54.275 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bulb_Temperatureâ received command OFF
01:13:54.297 [INFO ] [smarthome.event.ItemCommandEvent ] - Item âJohns_Bedroom_Led_Bulbâ received command OFF
01:13:54.310 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 305 to 306
01:13:54.362 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Temperature changed from 100 to 0
01:13:54.370 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Akis_Bedroom_Temperature
01:13:54.382 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Temperature_Group changed from 100.00000000 to 0.00000000 through Johns_Bulb_Temperature
01:13:54.385 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 80.00000000 to 40.00000000 through Akis_Bedroom_Led_Bulb
01:13:54.389 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bulb_Temperature changed from 100 to 0
01:13:54.394 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from ON to OFF through Johns_Bedroom_Led_Bulb
01:13:54.398 [INFO ] [home.event.GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from 40.00000000 to 0.00000000 through Johns_Bedroom_Led_Bulb
01:13:54.403 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from 252.9970245361328,0,80 to 252.9970245361328,0,0
01:13:54.407 [INFO ] [smarthome.event.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from 0.0,0,80 to 0.0,0,0
01:13:54.507 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 4 to 3
01:14:03.662 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 3 to 4
01:14:12.819 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 4 to 3
01:14:16.695 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 01:13:16 EEST to 2018-05-23 01:14:16 EEST
01:14:26.996 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 306 to 307
01:14:27.005 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_BinarySensor changed from ON to OFF
01:14:27.036 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 307 to 308
01:14:27.158 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 308 to 309
01:14:27.202 [INFO ] [smarthome.event.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 309 to 310
01:14:46.405 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 3 to 4
01:14:52.510 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 4 to 3
01:15:04.720 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 3 to 4
01:15:10.828 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 4 to 3
01:15:16.701 [INFO ] [smarthome.event.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 01:14:16 EEST to 2018-05-23 01:15:16 EEST
01:15:23.032 [INFO ] [smarthome.event.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from 3 to 4
As for the rules and the items I am currently using, I have them all made from paper ui and not from the terminal (I did the rules with the rule engine). Let me know if you need any specific information so I can provide them.
About the items involved in the rules opening and turning on the lights:
Items:
Bedrooms_Lights_Group (This is the group that contains two lights: 1: Akis_Bedroom_Led_Bulb, 2: Johns_Bedroom_Led_Bulb)
ZWaveNode6FGMS001MotionSensor_MotionAlarm (Is what my rule is checking if the state has changed from OFF to ON to activate the lights and from ON to OFF to deactivate them)
I have also implemented my self a rule to check for the luminance of the room whenever the luminance is changed and depending on that adjust brightness and additionally whenever that group is switched on check again for rooms luminance and adjust the brightness!
Here is the rule.
rule âBrightness adjustment depending on luminance valueâ
Item Bedrooms_Lights_Group changed from OFF to ON or
Item ZWaveNode6FGMS001MotionSensor_SensorLuminance received update
if (Bedrooms_Lights_Group.state == ON){
if (ZWaveNode6FGMS001MotionSensor_SensorLuminance.state > 65){
sendCommand(Bedrooms_Lights_Brightness, 45)
} else if (ZWaveNode6FGMS001MotionSensor_SensorLuminance.state < 35){
sendCommand(Bedrooms_Lights_Brightness, 80)
What we need is your openhab.log, not your events.log.
Even better, create a separate log file for zwave.
And please, use code fences when posting logs so we can read them
Hello, I am sorry for bad posting earlier. This is the log I am getting after starting Openhab from the log view.
Also, I tried removing and adding back the Z-wave sensor, at least 3-4 times, the sensor is recognized and connected its getting values for luminance, temperature and battery level, but the tamper, general alarm and motion alarm seems to be dead!
Let me know if u need additional information!
2018-05-23 15:03:17.735 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent [unknown:512] - org.openhab.io.transport.mqtt
2018-05-23 15:03:18.091 [INFO ] [.internal.GenericScriptEngineFactory] - Activated scripting support for ECMAScript
2018-05-23 15:03:25.397 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.1.20:8080
2018-05-23 15:03:25.435 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.1.20:8443
2018-05-23 15:03:26.312 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = a0164eec-8964-4aea-aa6d-6cb7e1b71703, base URL = http://localhost:8080)
2018-05-23 15:03:42.631 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.items'
2018-05-23 15:03:44.349 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2018-05-23 15:03:50.087 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-05-23 15:03:51.616 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.rules'
2018-05-23 15:03:51.663 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'home.rules' is either empty or cannot be parsed correctly!
2018-05-23 15:03:53.242 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.sitemap'
2018-05-23 15:03:54.042 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.things'
2018-05-23 15:03:54.057 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'home.things' is either empty or cannot be parsed correctly!
2018-05-23 15:03:54.379 [.ItemChannelLinkAddedEvent] - Link 'Johns_Bedroom_SignalStrength-lifx:colorlight:LifxBulb:signalstrength' has been added.
2018-05-23 15:03:54.390 [.ItemChannelLinkAddedEvent] - Link 'Akis_Bedroom_Led_Bulb-lifx:colorlight:D073D513FB20:color' has been added.
2018-05-23 15:03:54.404 [.ItemChannelLinkAddedEvent] - Link 'FibaroMotionSensorZWave_OOFBytesReceived-zwave:serial_zstick:162300857c1:serial_oof' has been added.
2018-05-23 15:03:54.409 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_FramesCancelled-zwave:serial_zstick:af8dbdd0:serial_can' has been added.
2018-05-23 15:03:54.413 [.ItemChannelLinkAddedEvent] - Link 'Node7_TamperAlarm-zwave:device:a597cf09:node7:alarm_tamper' has been added.
2018-05-23 15:03:54.425 [.ItemChannelLinkAddedEvent] - Link 'FibaroMotionSensorZWave_StartFrames-zwave:serial_zstick:162300857c1:serial_sof' has been added.
2018-05-23 15:03:54.432 [.ItemChannelLinkAddedEvent] - Link 'Johns_Bedroom_Led_Bulb-lifx:colorlight:D073D513EB9E:color' has been added.
2018-05-23 15:03:54.443 [.ItemChannelLinkAddedEvent] - Link 'FibaroMotionSensorZWave_FramesRejected-zwave:serial_zstick:162300857c1:serial_nak' has been added.
2018-05-23 15:03:54.446 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_OOFBytesReceived-zwave:serial_zstick:8ab1cec0:serial_oof' has been added.
2018-05-23 15:03:54.449 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_StartFrames-zwave:serial_zstick:a597cf09:serial_sof' has been added.
2018-05-23 15:03:54.452 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_StartFrames-zwave:serial_zstick:8ab1cec0:serial_sof' has been added.
2018-05-23 15:03:54.454 [.ItemChannelLinkAddedEvent] - Link 'Akis_Bedroom_Temperature-lifx:colorlight:D073D513FB20:temperature' has been added.
2018-05-23 15:03:54.459 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_OOFBytesReceived-zwave:serial_zstick:a597cf09:serial_oof' has been added.
2018-05-23 15:03:54.466 [.ItemChannelLinkAddedEvent] - Link 'Node7_SensorSeismicIntensity-zwave:device:a597cf09:node7:sensor_seismicintensity' has been added.
2018-05-23 15:03:54.469 [.ItemChannelLinkAddedEvent] - Link 'Node7_AlarmGeneral-zwave:device:a597cf09:node7:alarm_general' has been added.
2018-05-23 15:03:54.472 [.ItemChannelLinkAddedEvent] - Link 'Node7_MotionAlarm-zwave:device:a597cf09:node7:alarm_motion' has been added.
2018-05-23 15:03:54.475 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_StartFrames-zwave:serial_zstick:af8dbdd0:serial_sof' has been added.
2018-05-23 15:03:54.477 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_FramesCancelled-zwave:serial_zstick:8ab1cec0:serial_can' has been added.
2018-05-23 15:03:54.480 [.ItemChannelLinkAddedEvent] - Link 'Node7_BinarySensor-zwave:device:a597cf09:node7:sensor_binary' has been added.
2018-05-23 15:03:54.484 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_FramesAcknowledged-zwave:serial_zstick:a597cf09:serial_ack' has been added.
2018-05-23 15:03:54.486 [.ItemChannelLinkAddedEvent] - Link 'Johns_Bedroom_SignalStrength-lifx:colorlight:D073D513EB9E:signalstrength' has been added.
2018-05-23 15:03:54.489 [.ItemChannelLinkAddedEvent] - Link 'Node7_SensorLuminance-zwave:device:a597cf09:node7:sensor_luminance' has been added.
2018-05-23 15:03:54.492 [.ItemChannelLinkAddedEvent] - Link 'FibaroMotionSensorZWave_FramesAcknowledged-zwave:serial_zstick:162300857c1:serial_ack' has been added.
2018-05-23 15:03:54.499 [.ItemChannelLinkAddedEvent] - Link 'LocalTime_Date1-ntp:ntp:local:string' has been added.
2018-05-23 15:03:54.502 [.ItemChannelLinkAddedEvent] - Link 'Johns_Bulb_Temperature-lifx:colorlight:D073D513EB9E:temperature' has been added.
2018-05-23 15:03:54.507 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_FramesAcknowledged-zwave:serial_zstick:8ab1cec0:serial_ack' has been added.
2018-05-23 15:03:54.513 [.ItemChannelLinkAddedEvent] - Link 'Johns_Bedroom_Temperature-lifx:colorlight:LifxBulb:temperature' has been added.
2018-05-23 15:03:54.516 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_FramesCancelled-zwave:serial_zstick:a597cf09:serial_can' has been added.
2018-05-23 15:03:54.519 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_FramesRejected-zwave:serial_zstick:a597cf09:serial_nak' has been added.
2018-05-23 15:03:54.522 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_OOFBytesReceived-zwave:serial_zstick:af8dbdd0:serial_oof' has been added.
2018-05-23 15:03:54.529 [.ItemChannelLinkAddedEvent] - Link 'Johns_Bedroom_Led_Bulb-lifx:colorlight:LifxBulb:color' has been added.
2018-05-23 15:03:54.534 [.ItemChannelLinkAddedEvent] - Link 'FibaroMotionSensorZWave_FramesCancelled-zwave:serial_zstick:162300857c1:serial_can' has been added.
2018-05-23 15:03:54.537 [.ItemChannelLinkAddedEvent] - Link 'Akis_Bedroom_SignalStrength-lifx:colorlight:D073D513FB20:signalstrength' has been added.
2018-05-23 15:03:54.542 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_FramesRejected-zwave:serial_zstick:af8dbdd0:serial_nak' has been added.
2018-05-23 15:03:54.545 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_FramesRejected-zwave:serial_zstick:8ab1cec0:serial_nak' has been added.
2018-05-23 15:03:54.549 [.ItemChannelLinkAddedEvent] - Link 'Node7_BatteryLevel-zwave:device:a597cf09:node7:battery-level' has been added.
2018-05-23 15:03:54.552 [.ItemChannelLinkAddedEvent] - Link 'ZWaveSerialController_FramesAcknowledged-zwave:serial_zstick:af8dbdd0:serial_ack' has been added.
2018-05-23 15:03:54.556 [.ItemChannelLinkAddedEvent] - Link 'Node7_SensorTemperature-zwave:device:a597cf09:node7:sensor_temperature' has been added.
2018-05-23 15:03:54.863 [home.event.InboxAddedEvent] - Discovery Result with UID 'lifx:colorlight:D073D513EB9E' has been added.
2018-05-23 15:03:54.860 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'lifx:colorlight:D073D513EB9E' to inbox.
2018-05-23 15:03:55.006 [home.event.InboxAddedEvent] - Discovery Result with UID 'lifx:colorlight:D073D513FB20' has been added.
2018-05-23 15:03:55.007 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'lifx:colorlight:D073D513FB20' to inbox.
2018-05-23 15:03:55.256 [me.event.InboxRemovedEvent] - Discovery Result with UID 'lifx:colorlight:D073D513FB20' has been removed.
2018-05-23 15:03:55.397 [hingStatusInfoChangedEvent] - 'lifx:colorlight:D073D513FB20' changed from UNINITIALIZED to INITIALIZING
2018-05-23 15:03:55.576 [hingStatusInfoChangedEvent] - 'lifx:colorlight:D073D513FB20' changed from INITIALIZING to OFFLINE
2018-05-23 15:03:55.629 [hingStatusInfoChangedEvent] - 'lifx:colorlight:D073D513FB20' changed from OFFLINE to ONLINE
2018-05-23 15:03:55.642 [me.event.InboxRemovedEvent] - Discovery Result with UID 'lifx:colorlight:D073D513EB9E' has been removed.
2018-05-23 15:03:55.682 [hingStatusInfoChangedEvent] - 'lifx:colorlight:D073D513EB9E' changed from UNINITIALIZED to INITIALIZING
2018-05-23 15:03:55.702 [hingStatusInfoChangedEvent] - 'lifx:colorlight:D073D513EB9E' changed from INITIALIZING to OFFLINE
2018-05-23 15:03:55.813 [hingStatusInfoChangedEvent] - 'lifx:colorlight:D073D513EB9E' changed from OFFLINE to ONLINE
2018-05-23 15:03:56.333 [vent.ItemStateChangedEvent] - Johns_Bedroom_SignalStrength changed from NULL to 4
2018-05-23 15:03:56.337 [GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from NULL to OFF through Johns_Bedroom_Led_Bulb
2018-05-23 15:03:56.340 [vent.ItemStateChangedEvent] - Johns_Bedroom_Led_Bulb changed from NULL to 0.0,0,0
2018-05-23 15:03:56.358 [GroupItemStateChangedEvent] - Bedrooms_Lights_Group changed from OFF to ON through Johns_Bulb_Temperature
2018-05-23 15:03:56.364 [vent.ItemStateChangedEvent] - Johns_Bulb_Temperature changed from NULL to 15
2018-05-23 15:03:56.378 [vent.ItemStateChangedEvent] - Akis_Bedroom_SignalStrength changed from NULL to 3
2018-05-23 15:03:56.385 [GroupItemStateChangedEvent] - Bedrooms_Lights_Temperature_Group changed from NULL to 15.00000000 through Johns_Bulb_Temperature
2018-05-23 15:03:56.390 [GroupItemStateChangedEvent] - Bedrooms_Lights_Brightness changed from NULL to 0.00000000 through Johns_Bedroom_Led_Bulb
2018-05-23 15:03:58.906 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STARTING - org.openhab.io.transport.mqtt
2018-05-23 15:03:58.915 [DEBUG] [org.openhab.io.transport.mqtt ] - ServiceEvent REGISTERED - {org.openhab.io.transport.mqtt.MqttService, org.osgi.service.cm.ManagedService}={service.pid=org.openhab.mqtt, component.name=MQTT Connection Service, component.id=23, service.id=305, service.bundleid=234, service.scope=bundle} - org.openhab.io.transport.mqtt
2018-05-23 15:03:58.949 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STARTED - org.openhab.io.transport.mqtt
2018-05-23 15:03:58.963 [DEBUG] [penhab.io.transport.mqtt.MqttService] - Starting MQTT Service...
2018-05-23 15:03:59.006 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2018-05-23 15:03:59.010 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2018-05-23 15:03:59.028 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Creating new client for 'tcp://localhost:1883' using id 'openhab' and file store '/var/lib/openhab2/tmp/mosquitto'
2018-05-23 15:04:00.852 [ERROR] [penhab.io.transport.mqtt.MqttService] - Error starting broker connection
org.eclipse.paho.client.mqttv3.MqttSecurityException: Not authorized to connect
at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:28) [234:org.openhab.io.transport.mqtt:1.11.0]
at org.eclipse.paho.client.mqttv3.internal.ClientState.notifyReceivedAck(ClientState.java:990) [234:org.openhab.io.transport.mqtt:1.11.0]
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:118) [234:org.openhab.io.transport.mqtt:1.11.0]
2018-05-23 15:04:00.966 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection '//# broker'
2018-05-23 15:04:00.974 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Creating new client for 'tcp://192.168.1.20:1883' using id 'paho153352268677' and file store '/var/lib/openhab2/tmp///# broker'
2018-05-23 15:04:01.086 [ERROR] [penhab.io.transport.mqtt.MqttService] - Error starting broker connection
2018-05-23 15:04:01.094 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection '//mosquitto'
2018-05-23 15:04:01.096 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Creating new client for 'tcp://localhost:1883' using id 'openhab' and file store '/var/lib/openhab2/tmp///mosquitto'
2018-05-23 15:04:01.279 [ERROR] [penhab.io.transport.mqtt.MqttService] - Error starting broker connection
2018-05-23 15:04:01.287 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-05-23 15:04:01.289 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Creating new client for 'tcp://192.168.1.20:1883' using id 'openhab' and file store '/var/lib/openhab2/tmp/broker'
2018-05-23 15:04:01.354 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquito'
2018-05-23 15:04:01.357 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Creating new client for 'tcp://localhost:1883' using id 'paho153736198684' and file store '/var/lib/openhab2/tmp/mosquito'
2018-05-23 15:04:01.539 [ERROR] [penhab.io.transport.mqtt.MqttService] - Error starting broker connection
2018-05-23 15:04:02.088 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-05-23 15:04:02.800 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2018-05-23 15:04:02.937 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-05-23 15:04:03.265 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-05-23 15:04:03.560 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-05-23 15:04:03.591 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent STARTING - org.openhab.binding.mqtt
2018-05-23 15:04:03.597 [DEBUG] [.binding.mqtt.internal.MqttActivator] - MQTT binding has been started.
2018-05-23 15:04:03.663 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler}={event.topics=openhab/*, component.name=org.openhab.binding.mqtt.MqttItemBinding, component.id=237, service.id=364, service.bundleid=233, service.scope=bundle} - org.openhab.binding.mqtt
2018-05-23 15:04:03.686 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.mqtt.MqttBindingProvider}={component.name=org.openhab.binding.mqtt.genericbindingprovider, component.id=238, service.id=362, service.bundleid=233, service.scope=bundle} - org.openhab.binding.mqtt
2018-05-23 15:04:03.723 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={event.topics=openhab/*, service.pid=org.openhab.mqtt-eventbus, component.name=org.openhab.binding.mqtt.eventbus, component.id=239, service.id=365, service.bundleid=233, service.scope=bundle} - org.openhab.binding.mqtt
2018-05-23 15:04:03.731 [DEBUG] [ng.mqtt.internal.MqttEventBusBinding] - MQTT: Activating event bus binding.
2018-05-23 15:04:03.741 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent STARTED - org.openhab.binding.mqtt
2018-05-23 15:04:03.920 [hingStatusInfoChangedEvent] - 'ntp:ntp:local' changed from UNINITIALIZED to INITIALIZING
2018-05-23 15:04:04.064 [hingStatusInfoChangedEvent] - 'ntp:ntp:local' changed from INITIALIZING to ONLINE
2018-05-23 15:04:04.270 [vent.ItemStateChangedEvent] - LocalTime_Date1 changed from NULL to 2018-05-23 15:04:04 EEST
2018-05-23 15:04:04.641 [thome.event.RuleAddedEvent] - Rule '3a62dbdb-c49d-48fa-af34-f2602ff72c75' has been added.
2018-05-23 15:04:04.664 [.event.RuleStatusInfoEvent] - 3a62dbdb-c49d-48fa-af34-f2602ff72c75 updated: DISABLED
2018-05-23 15:04:04.669 [thome.event.RuleAddedEvent] - Rule 'b0bb60eb-1131-41fc-9688-ffebc7e79b0f' has been added.
2018-05-23 15:04:04.673 [.event.RuleStatusInfoEvent] - b0bb60eb-1131-41fc-9688-ffebc7e79b0f updated: DISABLED
2018-05-23 15:04:04.683 [thome.event.RuleAddedEvent] - Rule 'f4f85c80-2232-48ad-a907-f031ddf812b4' has been added.
2018-05-23 15:04:04.691 [.event.RuleStatusInfoEvent] - f4f85c80-2232-48ad-a907-f031ddf812b4 updated: DISABLED
2018-05-23 15:04:07.503 [vent.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_AlarmGeneral changed from NULL to ON
2018-05-23 15:04:07.547 [vent.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_SensorTemperature changed from NULL to 25.4
2018-05-23 15:04:07.571 [vent.ItemStateChangedEvent] - ZWaveNode6FGMS001MotionSensor_SensorLuminance changed from NULL to 20.0
2018-05-23 15:04:07.605 [vent.ItemStateChangedEvent] - Akis_Bedroom_Led_Bulb changed from NULL to 252.9970245361328,0,0
2018-05-23 15:04:17.730 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:a597cf09' changed from UNINITIALIZED to INITIALIZING
2018-05-23 15:04:17.803 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:a597cf09' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2018-05-23 15:04:17.813 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2018-05-23 15:04:17.853 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2018-05-23 15:04:17.887 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2018-05-23 15:04:17.950 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2018-05-23 15:04:17.955 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2018-05-23 15:04:18.101 [hingStatusInfoChangedEvent] - 'zwave:device:a597cf09:node7' changed from UNINITIALIZED to INITIALIZING
2018-05-23 15:04:18.123 [hingStatusInfoChangedEvent] - 'zwave:device:a597cf09:node7' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2018-05-23 15:04:21.015 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from NULL to 1
2018-05-23 15:04:21.025 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from NULL to 1
2018-05-23 15:04:21.100 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 1 to 2
2018-05-23 15:04:21.106 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 1 to 2
2018-05-23 15:04:21.139 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 2 to 3
2018-05-23 15:04:21.144 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 2 to 3
2018-05-23 15:04:21.165 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 3 to 4
2018-05-23 15:04:21.174 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 3 to 4
2018-05-23 15:04:21.197 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 4 to 5
2018-05-23 15:04:21.221 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 4 to 5
2018-05-23 15:04:21.229 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 5 to 6
2018-05-23 15:04:21.315 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 5 to 6
2018-05-23 15:04:21.323 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2018-05-23 15:04:21.327 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2018-05-23 15:04:21.334 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 3: Node found
2018-05-23 15:04:21.338 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 4: Node found
2018-05-23 15:04:21.341 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 5: Node found
2018-05-23 15:04:21.344 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 6: Node found
2018-05-23 15:04:21.346 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 7: Node found
2018-05-23 15:04:21.351 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2018-05-23 15:04:21.354 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2018-05-23 15:04:21.356 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2018-05-23 15:04:21.359 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 7
2018-05-23 15:04:21.362 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2018-05-23 15:04:21.379 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 6 to 7
2018-05-23 15:04:21.395 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 6 to 7
2018-05-23 15:04:23.797 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 7 to 8
2018-05-23 15:04:23.809 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 7 to 8
2018-05-23 15:04:23.855 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 8 to 9
2018-05-23 15:04:23.877 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 8 to 9
2018-05-23 15:04:23.902 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 9 to 10
2018-05-23 15:04:23.907 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 9 to 10
2018-05-23 15:04:23.946 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 10 to 11
2018-05-23 15:04:23.951 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 10 to 11
2018-05-23 15:04:24.016 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 11 to 12
2018-05-23 15:04:24.033 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 11 to 12
2018-05-23 15:04:24.184 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 12 to 13
2018-05-23 15:04:24.195 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 12 to 13
2018-05-23 15:04:24.221 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 13 to 14
2018-05-23 15:04:24.232 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 13 to 14
2018-05-23 15:04:24.249 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 14 to 15
2018-05-23 15:04:24.256 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 14 to 15
2018-05-23 15:04:24.279 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 15 to 16
2018-05-23 15:04:24.286 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 15 to 16
2018-05-23 15:04:24.316 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 16 to 17
2018-05-23 15:04:24.325 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 16 to 17
2018-05-23 15:04:24.352 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 17 to 18
2018-05-23 15:04:24.364 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 17 to 18
2018-05-23 15:04:24.377 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 18 to 19
2018-05-23 15:04:24.401 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 18 to 19
2018-05-23 15:04:24.419 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 19 to 20
2018-05-23 15:04:24.427 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 19 to 20
2018-05-23 15:04:24.447 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 20 to 21
2018-05-23 15:04:24.450 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 20 to 21
2018-05-23 15:04:24.480 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 21 to 22
2018-05-23 15:04:24.485 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 21 to 22
2018-05-23 15:04:24.505 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 22 to 23
2018-05-23 15:04:24.510 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 22 to 23
2018-05-23 15:04:24.526 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 23 to 24
2018-05-23 15:04:24.538 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 23 to 24
2018-05-23 15:04:24.567 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 24 to 25
2018-05-23 15:04:24.581 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 24 to 25
2018-05-23 15:04:24.606 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 25 to 26
2018-05-23 15:04:24.611 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 25 to 26
2018-05-23 15:04:24.625 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 26 to 27
2018-05-23 15:04:24.630 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 26 to 27
2018-05-23 15:04:24.652 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 27 to 28
2018-05-23 15:04:24.662 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 27 to 28
2018-05-23 15:04:28.905 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 28 to 29
2018-05-23 15:04:28.914 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 28 to 29
2018-05-23 15:04:28.934 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 29 to 30
2018-05-23 15:04:28.946 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 29 to 30
2018-05-23 15:04:28.976 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:a597cf09' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2018-05-23 15:04:28.991 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 30 to 31
2018-05-23 15:04:29.002 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 30 to 31
2018-05-23 15:04:29.009 [hingStatusInfoChangedEvent] - 'zwave:device:a597cf09:node7' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2018-05-23 15:04:29.031 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 31 to 32
2018-05-23 15:04:29.052 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 32 to 33
2018-05-23 15:04:29.063 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 32 to 33
2018-05-23 15:04:29.081 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 31 to 32
2018-05-23 15:04:29.085 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 33 to 34
2018-05-23 15:04:29.093 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 34 to 35
2018-05-23 15:04:29.100 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 35 to 36
2018-05-23 15:04:29.104 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 33 to 34
2018-05-23 15:04:29.107 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 34 to 35
2018-05-23 15:04:29.131 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 35 to 36
2018-05-23 15:04:29.144 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 36 to 37
2018-05-23 15:04:29.154 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 37 to 38
2018-05-23 15:04:29.166 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 36 to 37
2018-05-23 15:04:29.193 [hingStatusInfoChangedEvent] - 'zwave:device:a597cf09:node7' changed from ONLINE to ONLINE: Node initialising: WAIT
2018-05-23 15:04:29.206 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 37 to 38
2018-05-23 15:04:29.214 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 38 to 39
2018-05-23 15:04:29.220 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 38 to 39
2018-05-23 15:04:29.226 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 39 to 40
2018-05-23 15:04:29.229 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 39 to 40
2018-05-23 15:04:29.251 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 40 to 41
2018-05-23 15:04:29.265 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 40 to 41
2018-05-23 15:04:29.272 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 41 to 42
2018-05-23 15:04:29.279 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 41 to 42
2018-05-23 15:04:29.287 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 42 to 43
2018-05-23 15:04:29.293 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 42 to 43
2018-05-23 15:05:04.264 [vent.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 15:04:04 EEST to 2018-05-23 15:05:04 EEST
2018-05-23 15:06:04.273 [vent.ItemStateChangedEvent] - LocalTime_Date1 changed from 2018-05-23 15:05:04 EEST to 2018-05-23 15:06:04 EEST
2018-05-23 15:10:37.184 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 43 to 44
2018-05-23 15:10:37.197 [hingStatusInfoChangedEvent] - 'zwave:device:a597cf09:node7' changed from ONLINE: Node initialising: WAIT to ONLINE
2018-05-23 15:10:37.214 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 43 to 44
2018-05-23 15:10:37.219 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 44 to 45
2018-05-23 15:10:37.232 [vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 45 to 46
2018-05-23 15:10:37.285 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 7: Already processed another send data request for this callback Id, ignoring.
2018-05-23 15:10:37.289 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:a597cf09:node7' has been updated.
Nevermind, I fixed it! I have to factory reset my Zstick, my Fibaro and the Z-Wave binding, then I unlinked all the items from the things deleted all the items that had to do with Z-wave serial controller and the sensor. Rebooted the Raspberry Pi, installed the bindining included the serial controller and then the sensor. Rebooted again, clicked the Fibaro button to update its status and boom! There we go back on track! Everything works fine!
