Dunno if it’s due to my setup or a bug.
Setup: Raspi connected via USB to knx. eibd running on it and my OH1 lives on the same Pi. All good and running smoothly. (/usr/bin/eibd -d -D -S -T -i --pid-file=/var/run/eibd.pid usb:1:5:1:0:0) I use the same link for my Ets4 via IP.
Second Pi running OH2 and I try to use the OH1 Pi as KNX IP Gateway. (oh1 stopped during test)
I only get a connection to the knx bus via ROUTER:
–knx.cfg–
//IP of my OH1 Pi with eibd
knx:ip=192.168.1.110
//TUNNEL does not work
knx:type=ROUTER
// local ip makes no difference if localhost or external ip
knx:localIp=127.0.0.1
Issue: Can’t read any item status and can’t write commands to the bus.
If I use a switch item - the openhab.log starts filling with log entries (item received command ON) and won’t stop until a restart of the knx bundle.
