Just starting with OpenHab on a Raspberry 4 and I’m having an issue trying to write a floating point value to a ModBus RTU device.
I use a write transform as I need to set a number of registers at once to be able to change the parameters of the device.
So in my sitemap I have a setpoint:
Setpoint item=itm_vva_tstat_01_sp_heating label="Set point heating [%.1f °C]" minValue=10 maxValue=28 step=0.5
The thing:
Thing data vva_tstat_01_sp_heating "VVA TSTAT 01 - Set point heating" [readStart="196", readValueType="float32_swap", writeTransform="JS(vva_ts_rpc_sp_heating.js)"]
The writetransform:
(function(inputData) {
var obj = new Object();
obj.functionCode = "16";
obj.address = "70";
/* RPC_APP_ID, RPC_BSP_SAVE_CMD, PARAM_NUM , RPC_MAGIC_NR, PARAM_VALUE */
/* 4, 14, PN_TS_SP_HEATING = 618, 43605, inputData */
obj.value = [ 4, 14, 618, 43605, inputData];
obj.maxTries = "2";
/* Convert the object to a JSON string */
return "[ " + JSON.stringify(obj) + " ]";
})(input)
However, if fractional values are present (e.g. setpoint 20.5°C) nothing is sent as the binding does runs into problem with the floating point in the JSON.
2020-02-23 20:10:11.720 [WARN ] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:vva_tstat_01:vva_tstat_01_rtinfo:vva_tstat_01_sp_heating 'VVA TSTAT 01 - Set point heating' could handle transformation result '[ {"functionCode":"16","address":"70","value":[4,14,618,43605,"16.5"],"maxTries":"2"} ]'. Original command 16.5. Error details follow
java.lang.NumberFormatException: For input string: "16.5"
snip...
I am an absolute JS beginner so I am a bit lost on how to solve this, ideally I would like to convert the setpoint to a 32 bit floating point and then copy the 2 16 bit words to the JSON (this also allows for a word swap that would be handy) but I have no idea how to do that. I tried with some bit manipulation but
If someone can point me to an example or similar I’d be thankfull.
Steven
