After openhab upgrade I have many errors. Didn’t expect a bigger update, just did regular periodic apt-get “update/upgrade/dist-upgrade”.
So now I have many issues.
My charts are not working, I see errors like this ( I use rrd4j persistence):
2019-12-25 20:07:33.565 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'chart_p2' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2019-12-25 20:07:33.566 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'chart_p2' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2019-12-25 20:07:33.567 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2019-12-25 20:07:33.567 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve visibility item chart_p2 for widget org.eclipse.smarthome.model.sitemap.sitemap.Chart
2019-12-25 20:07:33.568 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve visibility item chart_p2 for widget org.eclipse.smarthome.model.sitemap.sitemap.Chart
2019-12-25 20:07:33.570 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve visibility item chart_p2 for widget org.eclipse.smarthome.model.sitemap.sitemap.Chart
2019-12-25 20:07:33.571 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve visibility item chart_p2 for widget org.eclipse.smarthome.model.sitemap.sitemap.Chart
Also some of my custom Items are suddenly not working/visible I’m guessing all of them?. Like:
//Switches
Switch GWLight "GW Light" {expire="30s,OFF"}
Switch HomeDimm "Home Dimm Light" {expire="40s,OFF"}
Number chart_p1 "Sensor Chart Period"
Number chart_p2 "Battery Chart Period"
Group gAC "AC" {alexa="Endpoint.Thermostat"}
Number ACTemp "AC Temp Setting" (gAC) {alexa="ThermostatController.targetSetpoint"}
Switch ACPower "AC Power" {alexa="Switchable"}
Number ACMode "AC Mode"
Switch DummyAC "DummyAC" {alexa="Switchable"}
Switch Edimax_battery "Edimax Battery" {channel="exec:command:battery:run"}
Switch EdimaxMotion "Edimax Motion Status" <motion> {expire="7s,OFF"}
Number EdimaxBatVoltage "Edimax Battery Voltage [%.1f V]" <battery> (gRestoreGroup)
DateTime EdimaxLastMotion "[%1$tY-%1$tm-%1$td %1$tH:%1$tM]" <clock> (gRestoreGroup)
Number EdimaxEvents "[%d]" <camera> (gRestoreGroup)
Switch EdimaxLowBattery "Edimax Low Battery" <energy>
String LivingRoomQuality "Living Room Air Quality" <airquality>
String BedroomQuality "Bedroom Air Quality" <airquality>
String KitchenQuality "Kitchen Air Quality" <airquality>
I tryied one advice noted here with the “clean-cache” approach but it’s stil the same. On the first look it seems all errors in openhab.log are related to my custom items mentioned above.
what’s the solution?
Thanks,
Mario
