- Platform information:
- Hardware: Raspberry Pi 4
- OS: Raspbian Buster
- Java Runtime Environment: 1.8.0_222
- openHAB version: Openhabian 2.5
i have some problems with counting my open windows. I use the deconz Binding (via Conbee II USB Stick) and Aqara Window Sensors. This works pretty good, but i can not count die amount of open windows.
In Paper UI i can see the state of the items, OPEN or CLOSED and even in the Basic UI Sitemap the Window Icons change when i open / close the windows. The Item “Offene Fenster” which should count always shows 0.
In the log i see an error message relating to the hueemulation which i do not understand.
What am i doing wrong?
items:
Group fensterunten
Group:Contact:OR(OPEN, CLOSED) OffeneFenster "Fenster offen [%d]" (fensterunten)
Contact Aqara_AZ_Nadine "AZ Nadine" (fensterunten) {channel="deconz:openclosesensor:0c523aaa:open"}
Contact Aqara_WoZi_Tuer "WoZi-TĂĽr" (fensterunten) {channel="deconz:openclosesensor:e2be84f8:open"}
sitemap:
Default item=Aqara_AZ_Nadine
Default item=OffeneFenster
Default item=Aqara_WoZi_Tuer
log:
2020-01-03 14:53:55.593 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'Aquara.items'
2020-01-03 14:53:55.602 [ERROR] [ore.common.registry.AbstractRegistry] - Cannot inform the listener "org.openhab.io.hueemulation.internal.rest.Sensors@93696a" about the "UPDATED" event: Item type not supported as sensor
java.lang.IllegalArgumentException: Item type not supported as sensor
at org.openhab.io.hueemulation.internal.dto.HueSensorEntry.<init>(HueSensorEntry.java:84) ~[?:?]
at org.openhab.io.hueemulation.internal.rest.Sensors.updated(Sensors.java:142) ~[?:?]
at org.openhab.io.hueemulation.internal.rest.Sensors.updated(Sensors.java:1) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.notifyListeners(AbstractRegistry.java:366) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.notifyListenersAboutUpdatedElement(AbstractRegistry.java:387) ~[?:?]
at org.eclipse.smarthome.core.internal.items.ItemRegistryImpl.notifyListenersAboutUpdatedElement(ItemRegistryImpl.java:379) ~[?:?]
at org.eclipse.smarthome.core.internal.items.ItemRegistryImpl.notifyListenersAboutUpdatedElement(ItemRegistryImpl.java:1) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:291) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:1) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:62) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListenersAboutUpdatedElement(AbstractProvider.java:87) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:398) ~[?:?]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:311) ~[?:?]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:149) ~[?:?]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:247) ~[?:?]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:310) ~[?:?]
at org.eclipse.smarthome.core.service.WatchQueueReader.lambda$3(WatchQueueReader.java:323) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_222]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
2020-01-03 14:53:55.619 [ome.event.ItemUpdatedEvent] - Item 'OffeneFenster' has been updated.
