when Updating from a Snapshot 2.5 from Build to Build the Lifelines and Associations are shown as node_1 instead of Controller after Update.
If I remove the things first, then Update and add the things again, there are some more problems:
Then in some things there ist shown node_1 instead of Controller, but most devices loose there association Groups and have to reconfigure! That’s a lot of Work for example with sensative strips to have been awaken several times.
Is there something I do wrong? or is that something with openhab behaviour?
Please provide a log showing that the associations are being removed. This should not happen in the latest binding as there is code to try and prevent this, so I would like to see how this happens.
Installed Update Snapshot from yesterday evening:
All Lifelines Motion Sensors gone
All Lifelines Sensative Strips gone, until now didn’t check the rest.
I’ve logged in Debug-Mode and saved log, so it will not be overwritten. Should I post that 6MB here? Or send it other way? That technical logging is to high for me
The logs show no removal of association groups. There is a known issue with displaying the multiple select data in the UI, so I suspect that is the problem, and not the actual configuration of the devices.
After Update, Motion Sensors stopped working, Windows Sensors stopped Working, Relays dont send Usage or Switch state anymore.
I first had to set lifelines and associations for Relays again.
Don’t think the Reason is in the devices, because earlier Updates i didnt had these Problems.
The Devices stop with next Wakeup, so they must get something from zwave Binding.
Last devices stopped today, maybe I have to log some more. Can you give me a hint for words to search for? Then I can log some more. 1 Day ist 40 to 80 MB of Debugging Logs and because of time differences shown at wakeup times, its not so easy to find the right part of log.
(Time Differences: sometimes there is a difference of 1 Hour in times shown in Webinterfaces, where i could look for wakeup times)
I think these association problems are compounded by the factor neither ui, Habmin nor PaperUI can reliability display the association parameters for an Item.
I believe what you say Chris in that associations are largely working fine, be it showing them as controller, node_1 or nothing - they still work but resetting them definitely helps some scenarios.
It would be great if the developers could resolve these UI bugs, I know not really in your domain though (Chris Jackson)
Resetting them will still be needed if you were running an old version of the binding. The new binding has some code to try and manage all the different types of configurations that I’ve seen thrown at the binding (strings, arrays, lists, arrays or lists). Additionally, the binding should now prevent the removal of associations that are either the lifeline (detected from the device - not any configuration) or from the “controller” tickbox in the database. So if the user tries to remove these associations - either on purpose or by mistake - it should not be possible.
If there are issues with this, then I would like to see logs showing the problem where the associations are removed.
