Thanks for your long detailed post!
A few answers:
No I don’t I use the same topic, just with command and state attribute, like this:
mqtt=">[mosquitto:shellies/shelly1-056C51/relay/0/command:command:*:MAP(shelly.map)],<[mosquitto:shellies/shelly1-056C51/relay/0:state:MAP(shelly.map)]"
All of my MQTT switches follows this method, only the transform is different…
What do you mean by this? I have one Switch which can send command and updates the state of that Switch Item as well.
I have set my AllLight group to mapdb persistence with everyChange, restoreOnStartup. Is that correct? It seems working but maybe I’m missing here also something.
Didn’t know that, I haven’t read the story of it, just a few things which was required to get to know better this protocoll. However I thought that this is not mainly created for this!
Thanks!
