I do have sensors for the garage door and do pulse red light when the door opens, switching to blue when the door has reached final position. Pulsing also red when closing.
This is completely senseless but gives a real cool effect
I learnt that âThred::sleepâ is not a good thing to do, especially when this exceeds one second. Therefore I want to optimize the code getting rid of âThread::sleepâ. This is more difficult than I thought. Right now the code is:
while(Ga_Garagentor_State.state == OPEN && Ga_Garagentor_Motion){
// pulse red
Ga_effect_co.sendCommand("0,100,100")
Thread::sleep(1200)
Ga_effect_co.sendCommand("0,100,10")
Thread::sleep(1200)
} //while
//as soon as door is open, switch on blue light
Ga_effect_co.sendCommand("250,100,100")
To my understanding, creating Timers within the while loop is not an option since this would just create a lot of timers and âwhileâ becomes senseless.
I tried to work with expire timers but this seems to make the code quite complex âŠ
Anything I missed or any other suggestions?
Thanks a lot
// pulse red
Thread::sleep(1200)
Thread::sleep(1200)
} //while
Step 1:
Create while loop with timer:
var timer = null // global variable
timer = createTimer(now, [ |
// pulse red
Thread::sleep(1200)
Thread::sleep(1200)
if(!(Ga_Garagentor_State.state == OPEN && Ga_Garagentor_Motion))
timer.reschedule(now.plusMillis(100))
else timer = null
Step 2:
Use timers inside the loop:
// pulse red
createTImer.now.plusMillis(1200), [ |
timer.reschedule(now.plusMillis(2400))
else timer = null
Are you using Hue bulbs?
You could just send the color and activate the alert channel with LSELECT.
This will let the bulb pulse in your desired color.
Yes, I am using Hue Light Strips and the alert channel works quite well. Even though it is a little bit faster and hence less âelegantâ than the 1200ms delay, I give it a try since it is a build-in function.
I changed the
condition and trigger the states with separate rules.
