I have pushbutton wall switch NO (at press NC).
For this I use a rule to link the correct input to relay.
Only the light goes on and off immediately.
Have tried different timer options but do not come out.
I was thinking to hold the change for a second.
Does anyone have an idea please?
code 1
rule "Turn light on off"
Item DI213 changed
if (RO210.state == OFF) {
RO210.sendCommand(ON)
else {
RO210.sendCommand(OFF) }
code 2
Item DI213 changed
timer = createTimer(now.plusMillis(500)) [|
timer = null
else {
timer = null
I have to assume that your Item “DI123” is linked to the momentary wall switch.
You are using both rules with the trigger “changed”, if it is a momentary switch you will have a change when pressing and when releasing. Both your rules would trigger twice. I suggest you only trigger on “changed to on”.
As @opus said, this should do:
Also you don’t really need the {} here because it’s a single instruction after the if/else statements
Item DI213 changed to ON //Button pressed
if (RO210.state == OFF) RO210.sendCommand(ON)
else RO210.sendCommand(OFF)
