In diving into my logs, I have found a problem that is leading to many other problems.
It is unable to find my quartz.properties file, and so is unable to do anything with the scheduler.
Launching the openHAB runtime...
osgi> 17:49:27.317 ERROR o.o.c.s.i.SchedulerActivator[:42] - initializing scheduler throws exception
org.quartz.SchedulerException: Properties file: './etc/quartz.properties' could not be found.
at org.quartz.impl.StdSchedulerFactory.initialize(StdSchedulerFactory.java:412)
17:49:31.217 WARN o.o.c.core.ConfigDispatcher[:305] - Could not check if job exists: Properties file: './etc/quartz.properties' could not be found.
17:49:31.287 INFO o.o.c.internal.CoreActivator[:61] - openHAB runtime has been started (v1.7.1).
17:49:36.630 ERROR o.o.c.p.i.PersistenceManager[:101] - initializing scheduler throws exception
So I went looking for the file myself, and here is what I found:
- Its location is defined as a command line argument in the OpenHAB launch script, current directory being /usr/share/openhab
- The file it wants is in /etc/openhab, and on Github it appears that it has been so for many years, having been moved there so that the runtime could find it !
- ./etc/ is actually a link to /etc/openhab/jetty/etc/, however I am unable to find this folder structure on Github
What confuses me is that the start.sh was recently updated to the 1.7 branch version as I updated my system (using APT method) as it overwrote it and I needed to put back my additional serial ports. So why isn’t it working with the updated version?
I was thinking about just changing the start.sh to point to /etc/openhab, but I don’t want to break things, and am wondering if there is anything else going on here that I need to take care of.
Can anyone shed some light on this?
