openHAB version: 2.4 as a Docker Container with mqtt
mqtt: binding version 2.4
Issue of the topic: I want the see the firmware version of my differents sonoffs s20 in the basic ui of openhab. At the moment i can only turn on/off my sonoffs, see the uptime and rssi value. In the console of my sonoff i can see that openhab send the command from my rule with mqtt. But the result is not visible in the basic ui. In my openhab logs i can not see any errors or hints for my problem.
Bridge mqtt:broker:mosquitto "Mosquitto" [ host="192.168.5.200", port=1883, secure=false, username="mqtt", password="XXXX", clientID="openHAB2" ]
// Sonoff01
Thing topic sonoff01 "Sonoff01" @ "Some Room" {
Channels:
Type switch : power "Power" [ stateTopic="tasmota/sonoff_55F735/stat/POWER", commandTopic="tasmota/sonoff_55F735/cmnd/POWER" ]
Type number : rssi "WiFi Signal Strength" [ stateTopic="tasmota/sonoff_55F735/tele/STATE", transformationPattern="JSONPATH:$.Wifi.RSSI"]
Type string : UPTIME "Uptime" [stateTopic="tasmota/sonoff_55F735/tele/STATE", transformationPattern="JSONPATH:$.Uptime"]
Type string : REACH "Reachable" [stateTopic="tasmota/sonoff_55F735/tele/LWT"]
Type string : version "Firmware Version" [stateTopic="tasmota/sonoff_55F735/stat/STATUS2", transformationPattern="JSONPATH:$.StatusFWR.Version"]
Sitemap configuration related to the issue:
Frame label="Debug"{
Group item=gDebugSonoff01 icon="settings"
Rules code related to the issue:
rule "Sonoff Maintenance"
Item Sonoff01_RSSI changed
// logInfo("sonoff.rules", "Sonoff Maintenance on all devices: " + receivedCommand)
val mqttActions = getActions("mqtt","mqtt:broker:mosquitto") // change to your broker name!
mqttActions.publishMQTT("tasmota/sonoff_55F735/cmnd/status","2")
2019-02-15 15:01:27.984 [vent.ItemStateChangedEvent] - Sonoff01_RSSI changed from 62 to 60
2019-02-15 15:01:33.288 [vent.ItemStateChangedEvent] - HS110_Power changed from 21.505 to 21.75
2019-02-15 15:01:33.289 [vent.ItemStateChangedEvent] - HS110_Current changed from 0.14 to 0.141
2019-02-15 15:01:42.563 [vent.ItemStateChangedEvent] - SunElevation changed from 19.33241646107857 to 19.24292134498016
2019-02-15 15:02:03.394 [vent.ItemStateChangedEvent] - HS110_Power changed from 21.75 to 22.492
2019-02-15 15:02:03.394 [vent.ItemStateChangedEvent] - HS110_Current changed from 0.141 to 0.144
2019-02-15 15:02:33.516 [vent.ItemStateChangedEvent] - HS110_Rssi changed from -36 to -37
2019-02-15 15:02:33.518 [vent.ItemStateChangedEvent] - HS110_Power changed from 22.492 to 20.626
2019-02-15 15:02:33.520 [vent.ItemStateChangedEvent] - HS110_EnergyUsage changed from 105.539 to 105.54
2019-02-15 15:02:33.520 [vent.ItemStateChangedEvent] - HS110_Current changed from 0.144 to 0.136
2019-02-15 15:02:42.571 [vent.ItemStateChangedEvent] - SunElevation changed from 19.24292134498016 to 19.15288688059389
2019-02-15 15:02:44.229 [vent.ItemStateChangedEvent] - Sonoff04_RSSI changed from 80 to 84
2019-02-15 15:03:03.618 [vent.ItemStateChangedEvent] - HS110_Rssi changed from -37 to -36
2019-02-15 15:03:03.619 [vent.ItemStateChangedEvent] - HS110_Power changed from 20.626 to 21.174
2019-02-15 15:03:03.620 [vent.ItemStateChangedEvent] - HS110_Current changed from 0.136 to 0.138
2019-02-15 15:03:17.597 [vent.ItemStateChangedEvent] - HS110_Rssi_02 changed from -58 to -57
2019-02-15 15:03:33.737 [vent.ItemStateChangedEvent] - HS110_Power changed from 21.174 to 20.484
2019-02-15 15:03:33.739 [vent.ItemStateChangedEvent] - HS110_Current changed from 0.138 to 0.135
2019-02-15 15:03:42.565 [vent.ItemStateChangedEvent] - SunElevation changed from 19.15288688059389 to 19.062333570372918
2019-02-15 15:03:47.798 [vent.ItemStateChangedEvent] - HS110_Rssi_02 changed from -57 to -58
2019-02-15 15:04:03.909 [vent.ItemStateChangedEvent] - HS110_Power changed from 20.484 to 21.168
2019-02-15 15:04:03.912 [vent.ItemStateChangedEvent] - HS110_Current changed from 0.135 to 0.139
2019-02-15 15:04:17.869 [vent.ItemStateChangedEvent] - HS110_Rssi_02 changed from -58 to -57
2019-02-15 15:04:33.999 [vent.ItemStateChangedEvent] - HS110_Power changed from 21.168 to 20.501
2019-02-15 15:04:34.000 [vent.ItemStateChangedEvent] - HS110_Current changed from 0.139 to 0.135
2019-02-15 15:04:42.565 [vent.ItemStateChangedEvent] - SunElevation changed from 19.062333570372918 to 18.971248654846054
2019-02-15 15:05:04.102 [vent.ItemStateChangedEvent] - HS110_Power changed from 20.501 to 22.34
2019-02-15 15:05:04.103 [vent.ItemStateChangedEvent] - HS110_Current changed from 0.135 to 0.144
2019-02-15 15:05:34.221 [vent.ItemStateChangedEvent] - HS110_Power changed from 22.34 to 20.277
2019-02-15 15:05:34.222 [vent.ItemStateChangedEvent] - HS110_Current changed from 0.144 to 0.135
2019-02-15 15:05:34.223 [vent.ItemStateChangedEvent] - HS110_EnergyUsage changed from 105.54 to 105.541
2019-02-15 15:02:32.759 [ERROR] [ansport.mqtt.internal.ClientCallback] - MQTT message received. MqttMessageSubscriber#processMessage() implementation failure
java.lang.IllegalArgumentException: json string can not be null or empty
at com.jayway.jsonpath.internal.Utils.notEmpty(Utils.java:386) ~[?:?]
at com.jayway.jsonpath.internal.JsonContext.parse(JsonContext.java:81) ~[?:?]
at com.jayway.jsonpath.JsonPath.read(JsonPath.java:502) ~[?:?]
at org.eclipse.smarthome.transform.jsonpath.internal.JSonPathTransformationService.transform(JSonPathTransformationService.java:62) ~[?:?]
at org.eclipse.smarthome.binding.mqtt.generic.internal.generic.ChannelStateTransformation.processValue(ChannelStateTransformation.java:81) ~[?:?]
at org.eclipse.smarthome.binding.mqtt.generic.internal.generic.ChannelState.processMessage(ChannelState.java:146) ~[?:?]
at org.eclipse.smarthome.io.transport.mqtt.internal.ClientCallback.lambda$3(ClientCallback.java:90) ~[225:org.eclipse.smarthome.io.transport.mqtt:0.10.0.oh240]
at java.util.ArrayList.forEach(ArrayList.java:1257) ~[?:?]
at org.eclipse.smarthome.io.transport.mqtt.internal.ClientCallback.messageArrived(ClientCallback.java:90) [225:org.eclipse.smarthome.io.transport.mqtt:0.10.0.oh240]
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.deliverMessage(CommsCallback.java:499) [221:org.eclipse.paho.client.mqttv3:1.2.0]
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleMessage(CommsCallback.java:402) [221:org.eclipse.paho.client.mqttv3:1.2.0]
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:206) [221:org.eclipse.paho.client.mqttv3:1.2.0]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
I don’t know, it should work…
Try:
Remove the transformationPattern
Then try changing the topic to Testing and send a payload with MQTTfx
Then add a transformation and send a JSON
I use exactly the same in my set-up, only difference is that I use the PaperUI to setup my things.
Textual things are too prone to errors in my opinion. Even though your looks ok.
two more restarts but without any solution. But i did not get the above error anymore. Anybody else has a hint? @vzorglub which tosmota firmware do you have? Maybe its a firmware bug?
I had 6.4.1 but reverted to 6.4.0
It’s not the tasmota, that’s working, we established that
Try creating an mqtt Generic thing in paperUI with one text channel for the firmware
