I am using HomeBuilder to setup my OH2 this time around so I get everything laid out how I want it and coded correctly. I am to the point where I think I need to add my MQTT code to make the connections to my Things work. At the end of the line below, it has {channel=""}. I’m assuming this is where I put the code for the MQTT connection?
I think this is where I ended up failing the last several times I got to this point. Maybe if I show what data I am using maybe I can be pointed in the right direction. Here is the information I’m getting from the Office_Light module:
00:00:00 Project sonoff Office_Light Version 6.4.1(sensors)-2_4_2
00:00:11 WIF: Connected
00:00:11 DNS: Initialized
00:00:11 HTP: Web server active on Office_Light-7724.local with IP address XXX.XXX.XXX.XXX
21:57:38 MQT: Attempting connection...
21:57:38 MQT: Connected
21:57:38 MQT: tele/Office_Light/LWT = Online (retained)
21:57:38 MQT: cmnd/Office_Light/POWER =
21:57:38 MQT: tele/Office_Light/INFO1 = {"Module":"Generic","Version":"6.4.1(sensors)","FallbackTopic":"cmnd/OL01_fb/","GroupTopic":"sonoffs"}
21:57:38 MQT: tele/Office_Light/INFO2 = {"WebServerMode":"Admin","Hostname":"Office_Light-7724","IPAddress":"XXX.XXX.XXX.XXX"}
21:57:38 MQT: stat/Office_Light/RESULT = {"POWER":"OFF"}
21:57:38 MQT: stat/Office_Light/POWER = OFF
22:03:08 MQT: stat/Office_Light/RESULT = {"POWER":"ON"}
22:03:08 MQT: stat/Office_Light/POWER = ON
22:03:10 MQT: stat/Office_Light/RESULT = {"POWER":"OFF"}
22:03:10 MQT: stat/Office_Light/POWER = OFF
When I go to set up the channel in the Paper UI
I add the channel as an On/Off Switch
Channel ID is OL01
Under channel Configuration
MQTT state topic is: stat/Office_Light/POWER
The MQTT command topic is cmnd/Office_Light/POWER,
At this point I don’t know what to put in the Incoming value transformation and the Outgoing value format. If I leave them blank, the relay turns on and off when I click the switch on the Basic UI screen with no errors in the Log file.
Also in the Items file, I did not enter anything for the channel="" statement. I am unsure if this is the correct way to make this work even though it does work.
Thoughts??
Thank you Vince!! My errors were coming from the text I was putting in the two places in the channel setup in the Paper UI. I guess I was making it harder that it actually was to set up. As I move on to the temperature and humidity sensor, I’m guessing I can do the same thing?
