waited a bit…
nothing happend…
connected again via putty:
2018-03-13_22:54:30_UTC [openHABian] Updating repositories and upgrading installed packages… FAILED
How many tries do you need to get it installed once and whats the problem of this?
I already tried to install it manually before (on latest raspbian stretch)…
there i was at least able to install openhab - but it gets stuck after trying to install the “Standard” package via the browser…
Hm … Installed a fresh openhabian on Pi 2 last Friday.
Runs fine.
Guess it’s your microSD card, which might be broken or your internet connection isn’t stable, as both errors occures during installing packages from the internet.
Maybe i’m wrong, but better check this first.
Same Wifi, same microSD (new Samsung Evo Plus with 94MB/s read/ 37MB/s write), same Samsung 5V 2A power supply (its used for month for Pi3 and Pi3B+).
Last message on putty: Waiting for openHAB to become ready…
Needed about 10min
Then fire up my Fox and browsed to the IP, chose “Standard” then “Log Viewer”.
11:35:04.270 [thome.event.ExtensionEvent] - Extension ‘ui-paper’ has been installed.
its now 20min after inserting the SD card… so it seems to work finally.
I have no idea what caused the 2 (!) failed attempts… same procedure like the 2nd try.
