Platform information:
- Hardware: Raspberry Pi 4 Model B, 2GB
- OS: openhabian
- openHAB version: openhabian-pi-raspbian-201908050414
Issue of the topic: Z-Wave Serial Controller is offline. I saw the Z-Stick once with lsusb, but it disappeared after restart. There is no change (lsusb or dmesg -w) when I insert or remove it. I tried a fresh installation, but the result was the same.
Z-stick is ok. I tried it in Windows OpenHab installation.
USB port ok. The USB drive is operating normally.
Any idea what’s wrong?
- Console command output:
[20:52:02] openhabian@openhab:~$ lsusb
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
[20:52:42] openhabian@openhab:~$ ls -l /dev/ttyA*
crw-rw---- 1 root dialout 204, 64 Sep 12 20:44 /dev/ttyAMA0
[20:55:42] openhabian@openhab:~$ cat /etc/group | grep dialout
dialout:x:20:openhabian,openhab
