I am trying to display the status of my Tesla Model 3 in Openhab2, using the old (pre 2.4) mqtt method.
I have not switched to mqtt 2.4 method yet, because I have a lot of Tasmota devices running via mqtt (defined in the items file) and have not used PaperUI for them, like for instance
Switch Stecker_Rechner “Steckdose DVBViewer Rechner” (KG_Technik) { mqtt=">[mosquitto:cmnd/sonoff-10155A/POWER:command:*:default],<[mosquitto:stat/sonoff-10155A/POWER:state:default]" }
When I subscribe to the Tesla topic via mqtt.fx, I receive something like
{“charging”:false,“driving”:false,“online”:true,“sleeping”:false,“speed”:82,“power”:21,“odometer”:13095.093747686564,“ideal_battery_range_km”:243.38156010106698,“outside_temp”:32,“battery_level”:49,“charger_voltage”:0,“charger_phases”:0,“charger_actual_current”:0,“charge_energy_added”:0,“charger_power”:0,“car_version”:“2019.28.3.1 f9e95acd”,“trip_start”:“13:46”,“trip_max_speed”:157,“trip_max_power”:288,“trip_duration_sec”:1226,“trip_kwh”:4.1268165505254473,“trip_avg_kwh”:170.59976834495549,“trip_distance”:24.190047797608713}
To display for instance Tesla ideal_battery_range_km I thought I can place a line like
Number Tesla_Rest km “Reichweite Tesla [%1.0f %%]” (gTesla) { mqtt="<[mosquitto:Tesla/ideal_battery_range_km]" }
in my items file - but this does not display anything.
Any hints and help is appreciated - thanks a lot!
P.S: The Tesla binding only works until the Model 3 goes to sleep - so its not a solution here.
