# \[SOLVED\] Reading values from a data-source for further usage in rules
**URL:** <https://community.openhab.org/t/solved-reading-values-from-a-data-source-for-further-usage-in-rules/71988>\
**Category:** Scripts & Rules\
**Created:** [April 8, 2019, 1:49pm UTC](https://community.openhab.org/t/solved-reading-values-from-a-data-source-for-further-usage-in-rules/71988 "2019-04-08T13:49:23Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![csi\_oh](https://community.openhab.org/user_avatar/community.openhab.org/csi_oh/32/53359_2.png) [@csi\_oh](https://community.openhab.org/u/csi_oh)\
**Post date:** [April 8, 2019, 1:49pm UTC](https://community.openhab.org/t/solved-reading-values-from-a-data-source-for-further-usage-in-rules/71988/1 "2019-04-08T13:49:23Z")
</div>
Hi there!
I’ve got a question regarding a way to retrieve values from a data-source in order to drive my rollershutters into a specific position.
First of all I’d like to mention that my rollershutter rule works fine. Basically I’ve defined 6 different “sun-states” like “morning”, “before noon”, “noon”, “afternoon”, “evening” and “night”. Each of these “sun-states” is defined by a combination of azimuth and elevation, provided by the astro-binding.
If the “sun-state” changes from one to another, hard-coded rollershutter-positions are sent to my KNX-bus. And this is the point where I’d like to ask for your ideas, because I’d love to have a seperate data-source where I can define the positions per state and item and OH just reads a specific datarow if needed.
That data-source doesn’t have to be a database, but it would be nice if it’s an “easy-to-read” thingy so if changes are needed I don’t have to touch the rule.
As always, many thanks in advance for your time & BR,
Chris
**Author:** ![Udo\_Hartmann](https://community.openhab.org/user_avatar/community.openhab.org/udo_hartmann/32/70871_2.png) [@Udo\_Hartmann](https://community.openhab.org/u/Udo_Hartmann)\
**Post date:** [April 8, 2019, 2:01pm UTC](https://community.openhab.org/t/solved-reading-values-from-a-data-source-for-further-usage-in-rules/71988/2 "2019-04-08T14:01:21Z")
</div>
Use an array or a hash map. 🙂
**Author:** ![rlkoshak](https://community.openhab.org/user_avatar/community.openhab.org/rlkoshak/32/75251_2.png) [@rlkoshak](https://community.openhab.org/u/rlkoshak)\
**Post date:** [April 8, 2019, 6:57pm UTC](https://community.openhab.org/t/solved-reading-values-from-a-data-source-for-further-usage-in-rules/71988/3 "2019-04-08T18:57:07Z")
</div>
If you have a simple mapping you can use a .map file and the transform Action. It’s a special case of [Design Pattern: Human Readable Names in Messages](https://community.openhab.org/t/design-pattern-human-readable-names-in-messages/34117). That would probably be the easiest approach that doesn’t involve hard coding the values into a Rule.
**Author:** ![5iver](https://community.openhab.org/user_avatar/community.openhab.org/5iver/32/21201_2.png) [@5iver](https://community.openhab.org/u/5iver)\
**Post date:** [April 8, 2019, 9:14pm UTC](https://community.openhab.org/t/solved-reading-values-from-a-data-source-for-further-usage-in-rules/71988/4 "2019-04-08T21:14:12Z")
</div>
If you use JSR223, you can utilize Item metadata for this, and keep the information _in_ the Item itself. I use this for all of my lighting, including color, and have also included timer values for longer delays and to shutoff speakers, etc. Here is an early writeup that I did…
> [@\[JSR223-Jython\] Read/add/remove Item metadata in rules](https://community.openhab.org/t/jsr223-jython-read-add-remove-item-metadata-in-rules/53868):
> In the Rules DSL, I used HashMaps, but now in JSR223, I use dictionaries to store data for particular Items. I use this data for setting the light levels based on the current time of day and the outdoor lux level. areaLightLevels = { "US\_DiningRoom\_Dimmer" : { "Morning" : {"Low\_Lux\_Trigger" : 20, "Level" : 30}, "Day" : {"Low\_Lux\_Trigger" : 90, "Level" : 30}, "Evening" : {"Low\_Lux\_Trigger" : 90, "Level" : 30}, "Night" : {"Low\_Lux\_Trigger" : 9…
**Post date:** [April 9, 2019, 11:25am UTC](https://community.openhab.org/t/solved-reading-values-from-a-data-source-for-further-usage-in-rules/71988/5 "2019-04-09T11:25:36Z")
</div>
Hi guys,
many thanks to all of you - I decided to go with arrays and wanted to share my working (simplified) result.
```auto
// don't forget to import!
import java.util.List
// get current rollershutter state (from other rule)
// it's important to cast to INT here, because otherwise you can't {get} the value at the desired array-index
var int current_rollershutter_state = (your_global_variable as Number).intValue
// initialize an array to store your desired positions per state
var List<Number> your_rollershutterpositions = newArrayList(10,20,30,40,50,60)
// retrieve the rollershutterposition for a given state
var Number specific_rollershutter_targetposition = your_rollershutterpositions.get(current_rollershutter_state)
// send command to a specific rollershutter
sendCommand(specific_rollershutter,specific_rollershutter_targetposition)
Thanks & BR,
Chris
