or UNDEF.
I use two 433 devices.
- The Sonoff RF Bridge + Portisch + Tasmota.
- A raspberry with https://github.com/merbanan/rtl_433 + USB RTL device (<10$)
My data is then sent using MQTT and dispatched to openhab.
Then I send a “switch on, off” command to my sonoff/tasmota lights using another MQTT channel.
Thanks for sharing the solution! I’m still having problems to make the bridge working. My doubt is that taking a quick look at your .items and .things it appears that you’re using the MQTT1. I changed all the .things and .items files to the MQTT v2, according to the documentation below:
So I’m asking if your files will work on the MQTT2 as above. Thank you!
